5.5 hp model# 247.883550- Valve/Timing Question - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 12-26-2014, 09:15 AM Thread Starter
Hello,
So I tried putting a new carb on this model and still it has not started. I checked the spark on the engine block and saw a bright blue spark. The carb pulls gas up through the emulsion tube just fine when I prime it. I also have tried priming the chamber.
I looked down into the chamber and pulled the engine over, the valves seem to open when they should and shut when they should.
When I try to start it with the electric start, All I get is some sputtering and a little backfire out the exhaust, but it never fully starts.
Does anyone know what the valve clearance should be? What should I check next?
jenkinsm2 is offline
post #2 of 15 Old 12-26-2014, 12:55 PM
Likes (Received): 82
I think you may want to try by elimination process on this one.
From your post you have spark and you gave it some form of gas with a backfiring and sputter.
Your next move would be to verify if you have a partially flywheel sheared key. And next might be the valves, but without the engine model# if flat head it would be .004 int. .008 exh or if ohv .004 on both. This is according to a Tecumseh engine specs book. I know Grunt and or Shryp would have exact specs from their database.
Good Luck
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Normex is offline
post #3 of 15 Old 12-26-2014, 12:56 PM Thread Starter
OK,
I just did a compression test, at 4-5 pulls and I get 60 psi. With the electric starter I get the same at 4-6 revolutions. I also tried putting a little oil into the chamber and the readings were the same after about 2 minutes of letting it sit.
Not sure if this is good enough, or what I should check next?
post #4 of 15 Old 12-26-2014, 01:04 PM Thread Starter
Hello,
What would a partially sheared flywheel key look like? The engine is LH195SP-67514, at least that is what is in the manual.
post #5 of 15 Old 12-26-2014, 01:15 PM
Originally Posted by jenkinsm2 View Post
Hello,
Your numbers confirms it's a flat head, as for a sheared key when they are in its original form it is a half moon shape key in a slot.
A sheared one would look like if you would have teared it a bit. Sorry but this is the best I could come with.
Normex is offline
post #6 of 15 Old 12-26-2014, 01:41 PM
Thanks (Given): 16
Likes (Received): 9
The top key is sheared... the bottom one is new
Ariens1976 is offline
post #7 of 15 Old 12-26-2014, 01:46 PM
[QUOTE] About a month ago, someone took apart the crankcase to replace the crankcase seal and the seal on the auger side around the crankshaft. Perhaps they put the flywheel on wrong? I really do not know how to check for correct compression of for proper ignition timing.[QUOTE]
Was this someone a small engine mechanic? And did he run the engine after his altercations? I would have had his take first if you didn't start the engine since his work last performed.
Normex is offline
post #8 of 15 Old 12-28-2014, 01:09 PM Thread Starter
Ok,
So I removed the flywheel and I think I accidently broke the flywheel key. I used a piece of wood and a rubber mallet, hit the flywheel from behind 3 times and it came off. But, the flywheel key looked really worn down. Not sure if it was put in wrong and then got worn or what. Buying a new key.
Is there a certain way the flywheel needs to go back on? I want to make sure it lines up right.
post #9 of 15 Old 12-28-2014, 01:18 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2041
Likes (Received): 517
Ok,
accidents happen! That's how we learn.
Once you set the key in the crankshaft, align the flywheel's keyway with key and slide it on...pretty straightforward.
Get a strap wrench for the outer flywheel rim and torque the flywheel nut to specified value....no more, no less. If it's under-torqued, you risk shearing the flywheel key. Too much torque and you risk snapping the crank shaft.
('87 Toro 38150 826)
post #10 of 15 Old 12-28-2014, 01:25 PM Thread Starter
Thank you,
So if I put the key into the crankshaft and flywheel right, then I do not need to align the flywheel with anything else on the engine or anything like that?
I used a soft piece of wood to stop the flywheel from moving so I could loosen the nut, can I do the same to tighten it, or is this bad? I do not have a big enough strap wrench, but I will buy one if need be.
Last, how do I know the "specified value", should I call tecumseh, and how would I know its right. Is it a certain number of turns?
