gas spitting out of carb - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 10-13-2013, 04:25 PM Thread Starter
Hey guys I have a craftsman snow blower 5hp and when it idles gas spits out of the carb its worse on high also when I prime it it over flows out of the carb please help
billy247 is offline
post #2 of 5 Old 10-13-2013, 05:42 PM
Overflowing during priming is somewhat normal. You probably don't have to push the button that many times. Spitting out while running it should not be doing. That almost sounds like timing.
Does it leak out when not running? That would indicate a bad float or needle/seat.
post #3 of 5 Old 10-13-2013, 05:59 PM Thread Starter
No it does not leak out when not running so how would I go about the timing
billy247 is offline
post #4 of 5 Old 10-15-2013, 01:58 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
I'd first try adjusting the main jet by turning the screw. Could be way out of adjustment, if it's an older carb that has the adjustment.
Jackmels is online now
post #5 of 5 Old 10-15-2013, 07:36 PM Thread Starter
I don't know if it has it I know it has an idle mixing screw and a high idle screw
billy247 is offline
