Won't stay in gear - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 02-02-2015, 07:11 PM Thread Starter
Won't stay in gear
So I'll put my Craftsman 536.886260 in Gear 1 (forward) and then after a bit it'll pop into Gear 2.
Why's this happening?
The only thing close to this problem I could find in the manual was 'excessive vibration' and it's not really vibrating excessively.
zamboknee is offline
post #2 of 9 Old 02-03-2015, 04:55 AM
I would say either the slot for 1st is worn out a bit or the handle doesn't have enough spring pressure to stay anymore. You can try grinding the notch a little deeper or bending the shifter tighter.
post #3 of 9 Old 02-03-2015, 06:38 AM Thread Starter
Nice. I'll check into the spring replacement maybe. There IS a spring for this shifter right?
post #4 of 9 Old 02-03-2015, 10:13 AM
Some use a spring and some just rely on pressure on the arm.
post #5 of 9 Old 11-21-2015, 09:05 AM Thread Starter
Part 800 here is described as 'Lever, Spring shift'
Is this the spring maybe?
Haven't had a chance to go outside and inspect yet
post #6 of 9 Old 11-21-2015, 10:39 AM
Thanks (Given): 173
Likes (Given): 453
Likes (Received): 1029
+ 1
post #7 of 9 Old 11-21-2015, 08:57 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
One other thing to check, is that the friction wheel slides freely on the shaft. If it doesn't slide all the way to the high position, it will want to pop back down a slot. The shafts can get rusty and will cause the wheel to not slide the full range of speeds.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #8 of 9 Old 11-22-2015, 07:42 AM
Thanks (Given): 11
I had a similar problems awhile back...heres the thread....hope it takes care of the problem for you. I have not had any more "jumping gear" issues! A few comments down there was a video attached that may help too...
https://www.snowblowerforum.com/forum...-out-gear.html
Marc Fish
Capital District area, NY USA
'06 Craftsman (MTD)#247.88790 9hp Tec 28"
2 stage Engine #LA318SA-156554
'95 Craftsman II (???)#536.886360 10hp Tec 30"
2 stage TracPlus (reclaimed)
Opfoto is online now
post #9 of 9 Old 11-22-2015, 08:23 AM
Thanks (Given): 588
Thanks (Received): 769
Likes (Given): 4353
Likes (Received): 1736
And here's the video from that thread. My Troy (MTD) has the same setup.
Thanks Big Ed, Opfoto thanked for this post
Likes Big Ed liked this post
