Wheel inflated!??? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 02-07-2015, 01:18 PM Thread Starter
Question Wheel inflated!???
Hey,
Just the other day, I noticed that my wheel was partially disassembled.
Partially meaning that my wheel valve on the left side of my snowblower, it was pushed into the wheel itself and as a result, the wheel was dislodged from the rim. Please see pictures.
Now, I tried to get the wheel off so I can fix the problem but here's the issue.
I have all the correct tools and when I tried to take the wheel off by loosing the nut on the rim, the whole wheel would turn and that would cause me to loosen nothing other then spin my wheel with my socket wrench.
Question now is, how do I take the wheel off?
Thank you.
P.S I have 2 pictures of a good wheel and the rest are of the bad wheel.
ID:	40010   Click image for larger version
ID:	40018   Click image for larger version
ID:	40026   Click image for larger version
ID:	40034   Click image for larger version
jon136 is offline
post #2 of 11 Old 02-07-2015, 01:24 PM
You most likely don't have to take the wheel off to fix it. Do you still have the old valve stem? You can pull it back through or put a new one in there with a valve stem tool. After that you can use a rope or ratchet strap around the tire to push the bead out and then air it back up. Alternatively you can put a tube in there.
I believe those bolts have some type of loctite on them and they can be stubborn. Maybe heat it a little to break the bond and then you can use the other wheel to hold it?
post #3 of 11 Old 02-07-2015, 01:26 PM
Ray 1962 10ML60's Avatar
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 24
You have to hold the wheel tight from spinning when you are trying to loosen the nut. Try to lock it in with your feet and then loosen the nut.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
post #4 of 11 Old 02-07-2015, 01:32 PM
Thanks (Given): 172
Likes (Given): 448
Likes (Received): 1026
Hey,
Welcome to the forum from the Keystone state. Let us know if/when you get it repaired.
post #5 of 11 Old 02-07-2015, 02:40 PM
Bob E's Avatar
Thanks (Received): 19
Likes (Given): 82
Likes (Received): 35
Also an impact wrench would zip it off pretty easy.
Bob E is offline
post #6 of 11 Old 02-07-2015, 07:40 PM
Thanks (Given): 172
Likes (Given): 448
I beliieve I'd be skeerd'to take an impact to any blower. There's nothing heavy enough on a blower to use an impact unless maybe a 3/8" impact. JMHO.
post #7 of 11 Old 02-07-2015, 07:45 PM
Duff Daddy's Avatar
Thanks (Given): 80
Thanks (Received): 17
Likes (Received): 15
3/8 impact to break it free. Big difference then tightening it with a 3/8 impact
96 Mustang - Race car
2005 Mustang - Daily Driver
15 Grand Cherokee Altitude - Mall Crawler
2007 Anderson Open Deck 19ft Trailer
1998 828D John Deere
1996 828D John Deere
2015 D110 John deere
ST724 Ariens not sure of year
1978 Ariens 924000
1964 10ML60D
Duff Daddy is offline
post #8 of 11 Old 02-07-2015, 09:24 PM
Bob E's Avatar
Likes (Given): 82
Yup. You also don't have to use max line pressure. I use my 1/2" impact on my outdoor power equipment and small engines regularly.
Bob E is offline
post #9 of 11 Old 02-08-2015, 04:43 AM
Yanmar Ronin's Avatar
Thanks (Given): 100
Thanks (Received): 83
Likes (Given): 81
Likes (Received): 404
If you have a strap-type oil filter wrench, you can use it to hold back against yourself while loosening the bolt, no scratches on the rim either.
Alternatively, wrap a loop of rope around it several times so it won't slip, stand on the rope and loosen away.
Yanmar Ronin is offline
post #10 of 11 Old 02-08-2015, 07:29 AM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 270
You could also brace the wheel by making a simple tool to hold the wheel by the hole. If you took a piece of wood and drove a screw into it then put that into the valve hole to wedge the wheel from turning. BTW make sure you know which way the nut is suppose to be loosened.
Zavie is offline
