Craftsman Snowblower Bouncing On Pavement - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-17-2015, 09:39 PM Thread Starter
I have a Craftsman model 536.887752. It has performed well for several years. Late last season it started to bounce and rock while I am blowing snow. It seems to be to low and catching the pavement. I've adjusted the skids and replaced the blade but it still catches & hits the pavement. Is this being caused by worn out skids? I have then down as low as they can go. Has anyone experienced this problem? Thanks
Redwood is offline
post #2 of 4 Old 02-17-2015, 09:47 PM
db9938's Avatar
Thanks (Received): 143
Likes (Received): 297
Welcome, it sounds as though your scraper bar is incurring some terrain obstruction. This could come from the scraper bar being adjusted too low, and possibly the skids.
Throw a paint stick under the scraper bar, and adjust the skids accordingly. Coins can also work for this, and give you a little variability in it's actually bite.
post #3 of 4 Old 02-17-2015, 10:11 PM
Thanks (Given): 30
Thanks (Received): 40
Also make sure tires are at pressure stated on the sidewall of the tire. Very low pressure could possible make it bounce.
The meltdown is under way ...
05' Toro 3650/ 6.5 RTek
Pathfinder13 is offline
post #4 of 4 Old 02-18-2015, 04:40 AM
Likes (Given): 1878
Likes (Received): 661
hello redwood, welcome to SBF!! check the auger housing and auger for signs of wear
