Craftsman 536-887992 snow blower - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 11-19-2013, 12:01 PM Thread Starter
Question Craftsman 536-887992 snow blower
What is the best way to drain the tank of old gas?
donludwig is offline
post #2 of 3 Old 11-19-2013, 12:31 PM
You should be able to remove the gas line from the carb and drain it into a can/bucket or whatever. It'll mostly gravity drain.
gravydude is offline
post #3 of 3 Old 11-19-2013, 12:31 PM
Siphon it out the fill hole or pull the fuel line off the bottom of the tank. If it has a shutoff valve under the tank turn it off, remove the line on the shutoff where it goes to the carb, put it into a gas can, then turn the valve back on.
