MTD engine surging a bit on low idle - tune up? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 06-11-2015, 05:07 PM Thread Starter
Probably just need to adjust the low/high idle screws, but is there a pictorial somewhere? Not even sure which bolts to remove to get the cover off.
NextYearInFlorida is offline
post #2 of 8 Old 06-12-2015, 12:46 PM
wdb
Thanks (Received): 23
Likes (Given): 43
Likes (Received): 69
Yep sounds like air/fuel mixture. Sorry can't help with diagrams but I suspect someone here can.
wdb is offline
post #3 of 8 Old 06-12-2015, 01:29 PM
2 screws on the side of the heater box and one near the dipstick, choke knob prys off
post #4 of 8 Old 06-12-2015, 02:17 PM
Thanks (Received): 52
Likes (Given): 266
Likes (Received): 108
Welcome to the Forum!
Pictures being worth so much, at least to me, I would suggest that you check out YouTube and look at Donyboy73's channel. He has great many videos on small engines in general and snowblowers in particular. His step by step videos, along with guidance from the nice folks that hang out here should get you through most any problem.
Larry
Snow Removal Equipment:
2014 Ariens Platinum 24
Blue Hill is offline
post #5 of 8 Old 06-12-2015, 06:00 PM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1741
Plenty of How to videos on youtube. Look for donnyboy73 as his are some of the best.
https://www.google.com/#q=tecumseh+c...nnyboy+youtube
post #6 of 8 Old 06-13-2015, 04:30 AM Thread Starter
This looks useful: site won't allow copy & paste. But usually ehow is lousy... Says there are 3 screws & where they are:
How to Tune an MTD Snow Thrower Carburetor | eHow
Locate the three carburetor (carb) adjustments screws on the carburetor. There will be one located on the top of the carb (power adjusting screw), one on the left side of the carb (idle mixture screw) and one on the bottom center of the carb (idle speed screw).
Now that's weird. Can't see the paste on this editor, even when I selected all & changed the font color to black; but it appeared when posted...
post #7 of 8 Old 06-13-2015, 10:19 AM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3341
Likes (Received): 679
I'm not sure which engine you have, so here is a link to all the MTD service manuals which should help. Just select the manual for the size engine you have.
Professional Shop Manuals
post #8 of 8 Old 10-10-2016, 07:33 PM
Likes (Given): 45
Likes (Received): 9
Normally "surging" means you have crap in the carb and it's not getting the required amount of fuel.... Usually a good cleaning will fix it... Install an inline filter and always use a screened funnel while filling... This routine has worked for me for 29 yrs on my blower... It never "surged" once....
Good luck.
1987 Craftsman Mod.C950528108 10/28...Techumseh Engine....SOLD
2007 Honda HS1132...GX340 Honda (Neighbor's)
2018 YT624EJ Yamahoooo..!
JamesReady is offline
