Newbie, just bought used Craftsman 28" 4x4 - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 07-19-2015, 10:55 AM Thread Starter
Hi: I was wondering how I might find existing posts for Craftsman 247.888540. It's 28", two wheels on each side ("4x4"), Tecumseh 9HP flathead engine. Originally sold in year 2000. I got it at a garage sale for $100. Made by MTD?
Seems solid, may need disk drive friction wheel rubber. Engine starts pretty easily, hunts some, might need carb rebuild I suppose. I have owner's manual and thus part numbers.
How is the turning supposed to work on these things? There is a little lever below each grip. If I squeeze one or the other nothing seems to change. This was just a trial run on my wooden deck.
(My other snowblower is a 1 season old Ariens 28" with the so-called self-turning feature.)
Thanks in advance! Tommy
Oilverland is offline
post #2 of 21 Old 07-19-2015, 11:59 AM
Generally those wheel triggers disconnect a clutch on the same side wheel. That makes the opposite side wheel push it to that direction.
post #3 of 21 Old 07-19-2015, 12:36 PM
Thanks (Given): 585
Thanks (Received): 765
Likes (Given): 4334
Likes (Received): 1727
Welcome to the forum Tommy
I haven't seen one before so I Googled it. Guessing it looks like this one ??
post #4 of 21 Old 07-19-2015, 12:53 PM
Likes (Received): 62
That model has 2 separate 1/2 axles that make up the axle. When you squeeze a trigger, the 1/2 axle on that side is disengaged and thus the wheel on that side doesn't turn. Squeeze the left trigger and it turns left and vice versa. I had a similar Craftsman with only 2 wheels and it was made by MTD.
CO Snow is online now
post #5 of 21 Old 07-19-2015, 03:00 PM
loneraider's Avatar
Thanks (Received): 14
Likes (Received): 15
Smile
Craftsman Snowblower Model 247.888540 (247888540) Parts from RepairClinic.com
This might help/
Ariens deluxe 28
Ariens 927le
ariens self propelled mower
loneraider is offline
Thanks bwdbrn1 thanked for this post
post #6 of 21 Old 07-19-2015, 09:13 PM
Thanks (Received): 238
Likes (Received): 608
Glad to have you join us. How bout a picture or two of that Craftsman if you can share them.
post #7 of 21 Old 07-20-2015, 11:31 AM
Thanks (Received): 379
Likes (Received): 1377
ALOHA from the paradise city.
post #8 of 21 Old 07-21-2015, 04:42 PM Thread Starter
Pix
Trying to attach pix, not sure I've got it to work...Yah it did. A couple of shrouds are removed for cleaning and inspection. Oh, and it turns left but not right, using the respective levers for that. I smell a project!
ID:	53289   Click image for larger version
post #9 of 21 Old 07-21-2015, 04:48 PM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 661
have to admit, have never seen that 4 wheel set up, only the gimmicky looking duals. it does look like its in good shape, nice $100 score! do you have the heater box and belt guard for it?
post #10 of 21 Old 07-21-2015, 05:31 PM
Likes (Given): 467
Likes (Received): 483
Talking
Here are a few more 4x4 snowblowers......
Likes lardness1 liked this post
