Craftsman 944.528396 Auger Shaft - Snowblower Forum : Snow Blower Forums
post #1 of 25 Old 08-23-2015, 09:01 PM Thread Starter
Hey.....I'm new to the site but I've noticed there's tons of info on here so hopefully I can get my problem sorted out. I am totally new to the snowblower scene so forgive me if my knowledge isn't that we'll. I received this 6 year old machine last week and is in excellent condition. Everything works as it should and can't wait to try it out. I was looking everything over and noticed the main shaft had roughly .5 to an 1 inch worth of play up and down. It's tight side by side. Even the plate that hurls the snow out the chute moves with it. When it's running, there is a small wobble but nothing serious at all. I took the belt cover off and there's no wobble in there that I can see. Any one have any ideas of this is a serious problem or is this somewhat normal? I can take a video once I figure out how to upload. Thanks so much!
youngjames832 is offline
post #2 of 25 Old 08-23-2015, 11:11 PM
the rear auger bushing needs to be replaced, it will caused decreased throwing performance
post #3 of 25 Old 08-24-2015, 05:05 AM Thread Starter
Ok thanks for your reply. I'll have to try and find a repair manual somewhere for it. Would this be considered a big job or pretty straight forward?
post #4 of 25 Old 08-24-2015, 08:52 AM
If it comes apart fairly easily it can be done in under 2 hours and maybe closer to 1 hour if you have done it before.
If everything fights you then it could take the whole weekend.
The front scoop has to be removed from the drive assembly, then the pulley has to be removed from the front scoop, then the auger assembly has to be pulled out the front. Then you can get to the bearing and put it back together.
Generally the hardest part is getting the pulley off if it is rusted on there. At 6 years old it shouldn't be too bad, but you wouldn't think it would be that shot already.
post #5 of 25 Old 08-24-2015, 09:28 AM Thread Starter
I'm hoping everything will come apart fairly easy. Every bolt that's viable is covered in liquid grease from the previous owner. Everything I have done so far came apart without issue. So would this very likely be the cause? Anything else I should look for? I found this video on YouTube.....is this pretty much what I'll have to do?
https://youtu.be/FgQI2k6it9Y
post #6 of 25 Old 08-24-2015, 11:47 AM Thread Starter
Here's a drawing that I have with the blower. Not sure how noticeable it is to read, but can someone point out the exact bushing(s) I need? Thanks again
post #7 of 25 Old 08-24-2015, 12:48 PM
part number 14
post #8 of 25 Old 08-24-2015, 05:21 PM
Thanks (Given): 82
Thanks (Received): 173
Likes (Given): 419
Likes (Received): 664
the way i read the post , it seems like the auger shaft bushings ( not shown in the posted exploded view) are the main issue ?
post #9 of 25 Old 08-24-2015, 06:59 PM
Likes (Received): 303
I read it the same way as nwcove. My thought was either way something must be missing to have 1/2 to 1 inch of play like a bushing or bearing fell out or was not assembled correctly after repair by previous owner.
post #10 of 25 Old 08-24-2015, 09:56 PM Thread Starter
So are the bushings you are referring to on that diagram I posted or would it be on a different diagram? Here's a quick video before my phone went dead to show what my problem is
