Craftsman 536-918300 belt cover - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 10-30-2015, 03:16 PM Thread Starter
I have an old Craftsman snow blower that works great but is missing the belt/pulley cover. Does anyone have an extra laying around that you would be willing to part with?
Edezra is offline
post #2 of 4 Old 10-30-2015, 10:18 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
Try ebay. Should you have difficulty finding one, you may be able to modify one from a different machine.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #3 of 4 Old 10-31-2015, 12:07 PM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1741
Welcome to the forum Edezra
Well , , Sears has it as NLA - Cover belt Part # 48534
There is one on Ebay for 2 more hours. Vintage Craftsman Driftbreaker 3 Stage Snowblower Belt Cover Pulley Guard | eBay
post #4 of 4 Old 10-31-2015, 01:39 PM
Likes (Received): 345
Most Any of the large frame blowers starting with 536, the plastic belt covers should interchange. Same with the smaller frame one - they interchange. What doesn't work is one from a smaller frame won't fit a larger frame. Three were some older machines with metal belt covers, those didn't swap for a plastic one at least the one I looked at.
They're either black or white and bolt up without a problem. Problem you'll run into is these are 20-30 year old machines and a lot of them are broken in the screw hole areas for whatever reason.
The large frame ones are pop riveted together, so if you find 2 broken ones broken in different areas, you may be able to combine them to make one good one.
HCBPH is online now
