Craftsman 536.88860 12.5/33" track drive won't move - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 11-24-2015, 10:37 AM Thread Starter
Hi guys,
First post here. I found an old online manual and it looks like the friction wheel is the culprit. Where do I find the friction wheel? Thanks!
deezldude is offline
post #2 of 14 Old 11-24-2015, 10:47 AM
Thanks (Received): 112
Likes (Received): 298
Originally Posted by deezldude View Post
Hi guys,
Try this link. The model number at Sears has one more zero on the end than the one you specified, but this might be it.
DRIVE ASSEMBLY Diagram & Parts List for Model 536888600 Craftsman-Parts Snow-Removal-Equipment-Parts | SearsPartsDirect
Work fascinates me.
skutflut is offline
post #3 of 14 Old 11-24-2015, 11:36 AM
Thanks (Given): 592
Thanks (Received): 773
Likes (Given): 4377
Likes (Received): 1744
Welcome to the forum Deezldude
There are different resources for finding the part number and purchasing the part. Searspartsdirect, partstree, repairclinic, jackssmallengine, ebay, ...
If you have an MTD, MTD has it's own web site as does Ariens. You're craftsman should be easy to find on CRAFTSMAN GAS SNOWTHROWER Parts | Model 536888600 | Sears PartsDirect
After you find the part number you need I'd shop around as Searspartsdirect is usually more expensive. It's likely you're Craftsman is made by MTD so you can try their site with the part number too. Snow Blower Parts: Replacement Snow Thrower Parts from MTD Parts
Once you have a part number you can try here: Parts Search | Prime®Line Power Equipment
And with the primeline number see if they carry it here: Home Page | O'Reilly Auto Parts
post #4 of 14 Old 11-24-2015, 11:42 AM
Thanks (Given): 592
Likes (Given): 4377
Is there supposed to be another "0" at the end of that model number ??
Are you sure it's the friction wheel ?? Is the rubber gone, maybe it's just a tension adjustment ??
post #5 of 14 Old 11-24-2015, 03:45 PM Thread Starter
Thanks for all the replies! This is a great forum. The rubber is almost all gone on the friction wheel so I'm guessing that's the problem. I'll start hunting it down tonight, and again, thanks!
post #6 of 14 Old 12-08-2015, 11:16 AM
The friction wheels can be had pretty cheap. For my model, the part is 1501435MA. I think that part is used on a lot of blowers, so it might even be for yours. They're $23 on amazon.
Have you tested your tracks to see if they move without the friction wheel engaged?
Alexsha is offline
post #7 of 14 Old 12-08-2015, 12:07 PM
Likes (Received): 303
Like K4frog mentioned look around and cross reference the part numbers. Usually taking the "replaced by part number" reference number. The "536" prefix in your model number was Craftsman's code for Western Tool and Stamping, then AMF, then Murray owned. Briggs took over Murray and now has many of their parts crossed to a Briggs number. Oregon or Stens will likely cross in there also.
post #8 of 14 Old 12-11-2015, 06:59 PM Thread Starter
Again, thanks for all the replies. My computer crashed and I lost the free online manual. Google doesen't help much either. any ideas?
post #9 of 14 Old 12-11-2015, 07:38 PM
Thanks (Given): 276
Thanks (Received): 331
Likes (Given): 3367
Likes (Received): 683
deezldude. I found the parts manual here, if you still need it.
post #10 of 14 Old 12-14-2015, 09:49 AM Thread Starter
Well, the friction disk isn't the culprit. The chain on the left side came off the sprocket and I don't see how I'm going to get the chain back on without some serious disassembly. Do the chains have a master link or does it require a complete takedown?
