Craftsman 536.885900 - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 12-02-2015, 01:13 PM Thread Starter
So I just purchased a new to me Craftsman 536.885900 snow blower. 8hp engine and 26" bucket. Built in 1989 and it looks maybe a few years old. I need to clean up the engine a bit (old gas), replace the drive cable (snapped at the handle), and lube up the tracks and drive components (the tracks will move an inch or 2 and stick, so there's definitely some rust in there). The auger and impeller work beautifully.
I'll take pictures as I tear into the drive components. Looking forward to getting this beast working like new.
ID:	65282   Click image for larger version
ID:	65290   Click image for larger version
ID:	65298   Click image for larger version
ID:	65306   Click image for larger version
ID:	65322   Click image for larger version
Alexsha is offline
Likes Eyeboltman, lardness1 liked this post
post #2 of 27 Old 12-02-2015, 02:56 PM
Likes (Received): 280
At least you don't have to worry about flat tires! I have passed up on the track units but I may rethink that...... some advantages I guess.
post #3 of 27 Old 12-02-2015, 04:47 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
You might find Critters Dragged a bunch of "Stuff" inside the chassis, Locking up the Drive, or Rusted Chains would do it as well....Let us know what you find inside...GL
Jackmels is online now
post #4 of 27 Old 12-02-2015, 09:39 PM
Likes (Received): 20
+1 for rusted chains
sidegrinder is offline
post #5 of 27 Old 12-02-2015, 10:27 PM
Thanks (Given): 590
Likes (Given): 4365
Likes (Received): 1742
Looks to be in pretty good condition. You might flip it up on it's auger and pull the pan covering the transmission and check out the mechanicals in there. Rusted chain or something likely hiding in there.
Likes lardness1 liked this post
post #6 of 27 Old 12-03-2015, 12:25 AM Thread Starter
Flipping it is the plan for this weekend. The tracks move a little, so I don't think it's rusted solid. As mentioned, probably a critter or rusted chain.
I need to get more info on the engine as its hard to start manually. Starts pretty well with the electronic starter though. Trying to decide if I should go with non-ethanol gas and some cleaning addatives or just give it the seafoam treatment.
Alexsha is offline
post #7 of 27 Old 12-04-2015, 10:32 PM
Thanks (Received): 112
Likes (Received): 298
If you have pure gas easily available, use it.
Work fascinates me.
skutflut is offline
post #8 of 27 Old 12-05-2015, 09:30 PM Thread Starter
There is a station not too far from here that sells non-ethanol gas. I need to pick some up.
Alexsha is offline
post #9 of 27 Old 12-07-2015, 06:40 PM Thread Starter
How freely should the bearings on the axle spin? I've gotten them moving, but it's fairly stiff and won't free spin. I haven't gotten the chain sprockets off yet, so I haven't been able to remove the bearings to really clean them out.
Alexsha is offline
post #10 of 27 Old 12-09-2015, 01:24 PM
Bearings should be fairly free moving and not feel rough or grate while turning. Hard to tell how free they are until you get the axles separated from each other by removing the chains. They could account for a lot of the drag if they are all dried up and rusty inside the links, rollers and sprockets. You are also trying to move 4 of them while the chains are attached. There will be some drag obviously, more if they are bushings, less if they are roller bearings.
Work fascinates me.
skutflut is offline
