Power clutch cable - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 01-13-2016, 03:07 PM Thread Starter
Power clutch cable
Hey guys. I have an older craftsman snowblower model 536.882600. The cable to engage the drive is broke. Sears don't offer it anymore. Does anyone know of a replacement cable for this snowblower? Or one that can be retro fitted to work. Thanks!
Trb6010 is offline
post #2 of 4 Old 01-13-2016, 03:45 PM
Is the plastic sheath still in good shape? I fixed a lawnmower by replacing the steel braided cable inside he sheath for dirt cheap. Sears wanted like $25 for a new cable and Home Depot wanted 22 cents per foot for the braided steel line. I took some small screws and drilled a hole through the side and crimped the cable by tightening the nut down.
For a window regulator on a car I fixed a broken cable the same way except I used the soldering method instead of the nut/bolt/crimp method. I didn't use the methyl hydrate though, I just used flux and solder.
Home Depot also sells little crush ferrules.
post #3 of 4 Old 01-18-2016, 06:03 AM
Likes (Received): 345
I found these some time back: McMaster-Carr
If you have enough cable left, they can be used to repair an end of a broken cable. You do need a clean end to join them onto.
HCBPH is online now
post #4 of 4 Old 01-19-2016, 09:50 AM Thread Starter
Sorry so late at getting back. Thank you this helps a lot!
Trb6010 is offline
