6.5hp on a 32" ?? - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 01-16-2016, 06:57 PM Thread Starter
lsengines's Avatar
6.5hp on a 32" ??
Ok so I have a 12/32 craftsman snowblower and I have to discard the old tecumseh motor..now I know a nice 13hp ohv would be best. But money is an issue so..
I have a brand new 6.5hp ohv, anybody know if they strong enough to work a full size blower??
lsengines is offline
post #2 of 11 Old 01-16-2016, 07:09 PM
Thanks (Received): 173
Likes (Given): 414
Likes (Received): 661
i would think you could get by with it in most situations , but you will have to use it like its a 24" bucket or less for heavy snowfalls.
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
Likes lsengines, 43128 liked this post
post #3 of 11 Old 01-16-2016, 07:24 PM
Thanks (Given): 172
Likes (Given): 448
Likes (Received): 1026
Yoiu're asking quite a bit from 6 ponies. You can try it. It may work ok under ideal conditions but nothing else. If this was a viable combination don't you think manufacturers would produce them? Save yourself a lot of grief and get a bigger engine.
post #4 of 11 Old 01-16-2016, 07:28 PM
Thanks (Received): 294
Likes (Given): 1874
Likes (Received): 656
I would go 8hp or more
post #5 of 11 Old 01-16-2016, 07:53 PM Thread Starter
lsengines's Avatar
Might look at my old 8hp tec. To see if any good. (10hp, the one on the blower, blowing oil thru pcv) 10 hp & 8hp 353cc and 318cc And my 6.5hp, 196cc (OHC)
post #6 of 11 Old 01-16-2016, 08:31 PM
Likes (Given): 467
Likes (Received): 483
I believe some older Ariens were 732 7hp to a 32" housing. I would think that if the 7 Tec engine was able to handle it than a 6.5 OHV engine will handle it (JMHO). It won't be a beast but It might work.
Post Thanks / Like - 1 Thanks, 4 Likes, 0 Dislikes
Thanks lsengines thanked for this post
Likes nwcove, 43128, lsengines, Kiss4aFrog liked this post
post #7 of 11 Old 01-16-2016, 09:36 PM
Thanks (Received): 112
Likes (Received): 298
6.5 for a 32 inch machine will be pushing it. I'm pretty sure that the bore and stroke are not the same on a 353cc and a 318cc engine.
Work fascinates me.
skutflut is offline
post #8 of 11 Old 01-16-2016, 09:40 PM
what if you sold the 6.5HP engine and added a couple bucks for more displacement? on that wide a blower i can see it being able to work with more than 6-8inches of snow.. deeper than that and i seriously think itl struggle way more than its worth...
someone mentionned Ariens used to have 7HP engines on 32in buckets way back. true but those 7HP engines had a good 2-3 ft-lbs of torque more than your 196cc OHV has to offer,, so they got by.. barely id think but got by
if you do but what we all know is going to be an undrpowered engine.. give it a chance.. purposely mis-adjust you shifter linkage to slow down the forwards movement.. or better still.. go forward bias until your neutral becomes a very slow crawling speed for the heavy snows.. might actually be useable then.. although i know (from experience as its how ive my blower set up for a crawling gear) youll find your friction disc wearring faster this way
1984 Columbia 10hp-33in
2015 Columbia 420cc 28in 3xHD
Marty013 is offline
Likes lsengines liked this post
post #9 of 11 Old 01-16-2016, 09:59 PM Thread Starter
lsengines's Avatar
yeah i think ill forget the little 6.5..ill see if i can do something with my tec.8hp ohv(i tought they had same displacement and bore and stroke than 10hp but bore is bigger on 10hp). My father's got an old briggs with a flo jet carb also(bout 35 years old)..looks like my hands gonna stay stained for a few days again.
post #10 of 11 Old 01-16-2016, 10:06 PM
Thanks (Given): 586
Thanks (Received): 765
Likes (Given): 4338
Likes (Received): 1727
If you're talking about a 6.5 predator it likely will get the job done and except for really heavy snow not be that noticeable.
I would however like to have something bigger.
