My new 10hp 32" Driftbreaker - what a beast! - Snowblower Forum : Snow Blower Forums
post #1 of 29 Old 01-21-2016, 01:18 AM Thread Starter
Thanks (Given): 39
Likes (Given): 46
Likes (Received): 6
My new-to-me Craftsman snowblower - model# 536.918500. It had been sitting in a garage for years, picked it up last month, just got to play with it tonight. Carb was reasonably clean, just a little gas must have been left in it, but the little that was turned in to a hard, thick varnish. LOTS of carb cleaner and elbow grease, put it together, tank flush and new plug, fired right up! We got a couple of inches here in the Pittsburgh area tonight, this guy made quick work of it. Really, REALLY throws the snow! Time to give it a real good once-over - change hoses, belts, lube, etc. Hoping to find a manual, nothing online - anyone have one? Also, looks like the oil was changed before storage, but I'd like to give it a fresh one. A Sears manual from the same era, with a 7hp Snow King recommends 5w30. That's probably 40 year old technology, wonder if there's a better oil recommendation. What do you all think? Think that's the best weight? Dino, synth blend or synth? Thanks in advance!
ID:	73761   Click image for larger version
ID:	73769   Click image for larger version
ID:	73777   Click image for larger version
wildbill59 is offline
Post Thanks / Like - 0 Thanks, 4 Likes, 0 Dislikes
Likes SlowRider22, GAR, classiccat, Chrysler 340 liked this post
post #2 of 29 Old 01-21-2016, 04:21 AM
Likes (Given): 1882
Likes (Received): 663
congrats on getting the driftbreaker up and running. as for oil most here use 5w 30 synthetic
Thanks wildbill59 thanked for this post
Likes wildbill59 liked this post
post #3 of 29 Old 01-21-2016, 08:45 AM
Likes (Received): 280
I don't know if I'd do synthetics on a guy that old. Stick with tried and true Dino on it. As a matter of fact I ad ZDDP in my old ones. Bobistheoilguy.com is a great reference place on all things oil
post #4 of 29 Old 01-21-2016, 05:07 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
That'a a great machine, should have bought one when I had the chance years ago. I have been using synthetic on my machine, FH Tech for the last 25 yrs. Original 50 yr Tech still runs great, and I never even have had the head off. As a concession to it's age, I only go 3/4 throttle, and it runs and throws snow great. Hoping for another 20 yrs, if I last that long.
Sid
Sid is online now
post #5 of 29 Old 01-21-2016, 05:39 PM
Thanks (Given): 589
Likes (Given): 4362
Likes (Received): 1741
I'm running 0-40 Mobil 1 in my 1032 (and others). Walmart has the best price. No problems
Name:	111213 536.918900  from the front.jpg
ID:	73897   Click image for larger version
Name:	Oil mobil 1 european formula.jpg
post #6 of 29 Old 01-21-2016, 07:17 PM
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
Nice machine, nice to see it still getting the job done in a big way. Who made these for Sears back in the day, was it Gilson?
Cardo111 is offline
post #7 of 29 Old 01-21-2016, 07:29 PM
Likes (Received): 20
Not Gilson. I would guess AMF.
sidegrinder is offline
post #8 of 29 Old 01-21-2016, 08:04 PM
Thanks (Received): 19
Likes (Given): 23
Likes (Received): 62
Congrats on a nice blower. I have one almost identical but
mine has the white housing for the lights.
As for oil, I have been using synthetic in all my snowblowers
with no issues at all.
Lee
John Deere TRS32
Craftsman 1032 Drift Breaker
John Deere 1032
Bolens 1032
John Deere 1032 Project
lee h is offline
post #9 of 29 Old 01-21-2016, 08:04 PM
Thanks (Given): 589
Likes (Given): 4362
Mine is a Noma. I get jealous every time I see one with the headlight assembly. Just can't get my hands on one for a price I'm willing to pay.
post #10 of 29 Old 01-23-2016, 06:37 AM
Likes (Received): 345
Congrats, you found yourself a great machine. Happens that one has the Tecumseh gear transmission in it vs a friction disk drive. It's a mean beast.
I have one of them, one of many I have bought, rebuilt and sold
Happens I have a garage door that's too narrow for a 32" auger housing to go through so I took a narrower auger housing and swapped it out for that one so become my perfect machine
Here's one thing to watch:
The bolts that hold the transmission to the mounting shaft inside the tractor unit can work loose, or if you have the drive chain jam it can break the mounting points on the transmission (note the top 2 mounts I've cut off. I came up with a repair method so if it happens don't trash it out as there is a repair method.
Biggest problem you may have is the drive cable from the hand control to the belt tensioner breaking or rusting up. Again there are options so don't give up on it.
One last thing. There is a way to split the auger and drive from a common control and have done that to one machine. Finding the right parts take a little time and you need to make a part but it's possible.
HCBPH is online now
Likes classiccat, wildbill59, lee h liked this post
