Question on older 5/22 blower 247.88700, Impeller mod? - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-21-2016, 07:10 PM Thread Starter
Just picked up a NICE used 5/22 Craftsman blower for cheap. I seen it had a plastic impeller and I was wondering if its worth doing the impeller mod or not. Any input? It has about 3/8"-1/2" clearance between the impeller to the housing.
BohNatty is offline
post #2 of 8 Old 01-21-2016, 07:17 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
to the forum BohNatty
Don't know on that one, sorry. Hopefully someone with some experience on them will pipe up.
post #3 of 8 Old 01-21-2016, 07:32 PM
The official Clarence site recommends against using them on plastic impellers. You can go for it and hope for the best. Perhaps price out a replacement impeller first just in case.
post #4 of 8 Old 01-21-2016, 07:35 PM Thread Starter
There is a price on it, but the impeller seems to be out in some places. Maybe I should pull it off at the end of the season and try to make a steel one? Unless they make a steel one for it, like a replacement or one that will work
BohNatty is offline
post #5 of 8 Old 01-21-2016, 08:10 PM
Thanks (Given): 276
Thanks (Received): 330
Likes (Given): 3355
Likes (Received): 679
to SBF BohNatty. If you measure the impeller diameter, number of blades, blade length and shaft size, someone here with parts machines may be able to find a suitable metal impeller for you. Hopefully.
post #6 of 8 Old 01-21-2016, 08:12 PM Thread Starter
Alright, were about to get 24+" up here. So I think after the snow and come spring time, I'll tear her down.
BohNatty is offline
post #7 of 8 Old 01-21-2016, 08:27 PM
Likes (Given): 1885
Likes (Received): 663
hello bo, welcome to SBF!! if you get a ton of snow just take it easy and don't over speed your machine, you don't want to break it now. then decide if its actually worth putting a steel impeller on or if it would be better to get a more robust machine and sell the craftsman
Likes Grunt liked this post
post #8 of 8 Old 01-21-2016, 10:03 PM Thread Starter
That's true. I mean it seems to be pretty stout little machine. But it may be a better machine for lighter work. I'm going to stay on top of it regardless...
BohNatty is offline
