snow keeps sticking to augers - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 01-24-2016, 04:35 PM Thread Starter
How do u fix it next question motor is very tired going to put a cheep harbor freight motor on it it should work right
matthewrich is offline
post #2 of 14 Old 01-24-2016, 04:46 PM
Thanks (Given): 592
Thanks (Received): 773
Likes (Given): 4377
Likes (Received): 1744
You can use fluid film.
post #3 of 14 Old 01-24-2016, 05:01 PM
Likes (Received): 1384
Well now everybody lets just say that with any kind of snow. there is always going some that just never leave even after the party's over. that is my 50 pence for the day anyway.
post #4 of 14 Old 01-24-2016, 10:44 PM
The other option is sand, paint and wax.
Snow loves to stick to rough and rusty stuff.
Likes Kiss4aFrog, detdrbuzzard liked this post
post #5 of 14 Old 01-25-2016, 06:03 AM
Likes (Received): 345
You can also use "PAM" cooking spray to coat the inside of the auger housing and the chute to improve it's slipperiness. Especially if it's the sloppy wet stuff, it's harder to get the impeller to push it out.
HCBPH is online now
post #6 of 14 Old 01-25-2016, 06:33 AM
Likes (Received): 483
Plenty of succesful HF repowers . Look into this section of the forum
Re-Powering - Snowblower Forum : Snow Blower Forums
post #7 of 14 Old 01-25-2016, 06:35 AM
Thanks (Given): 178
Thanks (Received): 310
Likes (Given): 470
Likes (Received): 1053
+1 on the Pam spray. You can buy he expensive stuff like silicone sprays or WD-40 or whatever. Pam works as well as anything. I buy the cheap, generic stuff and it works very well. Also, as SHRYP pointed out, clean your augers and give them a good coat of paint and then wax. There are some guys who use ski wax etc but inexpensive Pam cooking spray does great for me. I think if I did use something else it'd be pure silicone spray.
post #8 of 14 Old 02-09-2016, 10:40 AM
Thanks (Given): 592
Likes (Given): 4377
Has anyone tried this silicone chute lube from CRC
03204 -- Chute Lube® Lubricant, 11 Wt Oz
post #9 of 14 Old 02-09-2016, 11:07 AM
Thanks (Given): 178
Likes (Given): 470
Been using the cheap cooking spray for years and it always works. By the time it wears off the whole machine has become acclimated to ambient temp and has very little snow sticking. You have to realize the auger really isn't turning all that fast and the snow up against the auger shaft is likely to stick there more than anywhere else. Also the sides of the bucket. I spray these areas pretty heavy and it really helps.
post #10 of 14 Old 02-09-2016, 10:12 PM
Thanks (Received): 28
Likes (Received): 58
Smooth clean slick surfaces will help tremendously but If the motor is that tired rpm will go down giving the snow time to stick to everything.
Sometimes no rhyme or reason to it. I revamped an older large frame simplicity that hadn't been used in years. I did the work but wasn't going to sand and paint, the owner could do that. He didn't. That machine threw snow like no tomorrow and never clogged
td5771 is offline
