Craftsman - 9HP "Tecumseh" New Carb - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 01-25-2016, 05:39 AM Thread Starter
Hi all, new to the forum, I have an older model Craftsman snowblower, the "Green Beast" with a Tecumseh 9 HP motor, I swapped out the carb due to the old one being a complete mess, but still it stalls under load, and seems to be using way too much fuel. The carb does not have any settings screws, except idle and the main screw under the bowl, valve issue perhaps ? Or other setting I do not know about, assuming carb is set correctly "out of the box".
Nordon is offline
post #2 of 3 Old 01-25-2016, 06:33 AM
It could be related to the valves. As those Tecumseh's get older the valves start to not close all the way as they heat up. Might need to check the adjustment and grind the stems a little.
Could also have something to do with the governor or the new carb.
post #3 of 3 Old 01-25-2016, 09:29 AM Thread Starter
That would make sense as it seems it runs much better for the first few mins, then seems to get worse after 5-10 mins of runtime. Thanks!
Nordon is offline
