Craftsman 536.886400 running issues - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-27-2016, 10:45 AM Thread Starter
Hello all. I just picked up the snow blower from my BIL. From what I can tell it is has a Tecumseh 4HP engine and was made around 1987 or so. I've attached a couple pictures as well. I replaced the fuel line before using on Saturday since it had a hole from the previous owner not routing the line correctly I'm assuming. I just bought some 1/4" ID fuel line from the auto parts store.
Worked pretty good for a day. Now when I go to start it, it fires up and dies instantly UNLESS I keep pressing the primer button. Does this sound like a carburetor problem or something else?
Any ideas would be helpful and appreciated.
Thanks,
dave
Hokie-Dave is offline
post #2 of 7 Old 01-27-2016, 12:12 PM
Definitely a carb issue.
post #3 of 7 Old 01-27-2016, 12:28 PM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1741
There might also be a screen in the fuel tank that's plugged. If you pull the fuel line off the bottom of the tank or at the carb see if it flows properly.
Could also be something like the needle in the carb that regulates how much fuel comes in getting stuck too.
Likes Grunt liked this post
post #4 of 7 Old 01-27-2016, 12:54 PM
Thanks (Given): 275
Thanks (Received): 330
Likes (Given): 3341
Likes (Received): 679
to SBF Dave.I agree with cleaning the carb. Replacing the fuel line probably allowed dirt or shredded rubber to block one of the internal ports on the carb. Here is a link to different Tecumseh carbs to help you understand how they work. Just pick the series carb that matches yours.
Small Engine, Lawn Mower, Snowthrower Troubleshooting, Repairs and Safety
post #5 of 7 Old 01-27-2016, 01:52 PM Thread Starter
Thanks for the replies. I'll check and see if there is a screen clogged in the tank, but the tank seems like it empties just fine. I've had it off a couple times already. I've just ordered a new carb since it seemed just as cheap if not cheaper than rebuilding / cleaning it, especially with it being almost 30 years old.
On another note, any ideas what to look for as a reason that the wheels don't seem to propel the machine? It does say it is a dual stage, which I assume means the wheels should be driven also?
dave
post #6 of 7 Old 01-27-2016, 02:02 PM
Likes (Received): 280
YEP - a few things to look at while your in the ordering mood! ;>P Pop off the belt cover as well as the bottom plate on the tractor. Look a the the belts (condition) and tensioner - then look when the cables are actuated and see if it has good tension. Look underneath at the friction disk/wheel. Is the rubber hard/cracked, is it making good contact and is the wheel free of gunk.......
post #7 of 7 Old 01-27-2016, 02:04 PM
Likes (Given): 1882
Likes (Received): 663
hello dave, welcome to SBF!! could need a new belt, might as well replace the auger belt while doing the drive belt that way your good to go and know how old your belts are
