Brake Arm Brake Pad - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 03-17-2016, 09:51 PM Thread Starter
Brake Arm Brake Pad
Can anyone tell me a good replacement for the 1"x 1" pulley brake pad. I drilled out the two rivets holding in the pad and removed the old one. I figure I can bolt in a new pad. This is for Craftsman driftbreaker 536.882700
bigragu98 is offline
post #2 of 14 Old 03-18-2016, 07:39 AM
Likes (Received): 345
I suspect any place that can rebond/rebuild brake pads could put on some new material. Shops did that for years, but now days with disposable pads, I'm guessing many shops don't have the experience or tools to do it today so you may have to look for 'old school' shops.
Drum brake pads used to be riveted to the backing so any place that could rebuild hem should be able to do it.
HCBPH is online now
post #3 of 14 Old 03-18-2016, 11:30 AM
I have heard people suggest a piece of leather or maybe an old leather / rubber belt.
post #4 of 14 Old 03-18-2016, 11:36 AM
Thanks (Given): 14
Likes (Given): 44
Likes (Received): 50
What's the brake for?
Rob711 is offline
post #5 of 14 Old 03-18-2016, 01:01 PM
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
It is for the impeller.
Have you tried looking for the correct part on line from Sears or Jacks?
If it is no longer available look on EBay as you can sometimes find used stuff in good shape there.
I would go with a thick and hard piece of leather. A piece of hard wood may work for a while.
As HCBPH said most auto brake pads today are bonded and not riveted.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #6 of 14 Old 03-18-2016, 05:17 PM Thread Starter
Found one on fleabay. Its a 1"x1" x .25" and should I should be able to bolt/epoxy it in place. Thanks for your replies
post #7 of 14 Old 03-19-2016, 06:30 AM
Larry
Epoxy won't hold over time by itself IMO, I wouldn't rely on epoxy only to hold it over time and I wouldn't use a bolt. I'd look for some place like a farm supply and get a flat head copper rivet of the right diameter and length (along with the corresponding washer you use to peen it over). That's what I'd use so if it comes in contact with things like the belt or pulley the rivet would be sacrificial unlike a bolt which could tear them up instead.
My 2 cents.
Paul
HCBPH is online now
post #8 of 14 Old 03-19-2016, 08:34 AM
Thanks (Given): 67
Likes (Given): 115
I generally agree with Paul, you don't want to allow the fastener (rivet or bolt) to come in contact with the belt or pulley. So a soft copper rivet would be the safest choice. Copper would still eat up your belt but not the pulley. However, since it is 1" wide you may be able to get away with a couple of small screws or rivets in the corners if they will not be over the belt. You will have to look at the alignment and choose the best orientation. Although today, epoxies are getting better and better. You may want to check out what Devcon or 3M has at an industrial supply house. There may be some new high tech super epoxy out there. Get the one with the highest shear strength that you can work with and try an experiment.
Current machines
Ariens 926LE
post #9 of 14 Old 03-19-2016, 08:58 AM Thread Starter
Thanks gentlemen. The two mounting holes for the brake pad I believe are wider apart that the width of the pulley. I should be able to use a few bolts and it should clear the pulley. If not, I'll pick ups some rivets that you mentioned.
post #10 of 14 Old 03-19-2016, 10:01 AM
Thanks (Given): 14
Likes (Given): 44
So there's machines with impeller brakes? When do u use them? Is this another unnecessary safety addition, a cya by manufacturer? Not to hyjack your thread big ragu, I'm intrigued. I can't see the circumstance when I thought apply impeller brake!
Rob711 is offline
