Help id old driftbreaker model - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 10-26-2016, 04:57 PM Thread Starter
hello and thanks for reading this, ive got an older driftbreaker i picked up from a friend. at some point in time this machine was painted and many of the tags and stickers are missing so this is what i know (or believe to be true)Main goal is to figure out the model so i can find parts.
PICS TO FOLLOW (when i figure it out..)
Photo in my profile garage
craftsman driftbreaker red/white
2 stage
14" impeller
24" auger (blade actual size), size of body out/out measures 25.75"
??? HP
tecumseh motor-4 cycle short block horizontal
SBH-351A (5009F)
code: 143-766162 ser 02360
Im looking to fix this before the snow flies thats why im hoping someone can help me id with a model number(need parts). The machine runs, but could use some tlc (new carb/rebuild, muffler, electric starter if i can find one for a reasonable price)
mike2me is offline
post #2 of 10 Old 10-26-2016, 05:21 PM Thread Starter
Does anyone know a good place to find a carburetor for this motor, Im having no trouble finding engine internals but i cant seem to find the correct carb or muffler for this motor from the common google sources like jackssmallengines or tecumsehpartsstore.
Im currently looking but if anyone has a go to source while i continue browse that would be appreciated
mike2me is offline
post #3 of 10 Old 10-26-2016, 10:11 PM Thread Starter
Idk of any of this information is useful or if anyone knows of a proper source to look it up but i may have found the model number 536918400.
I did not find this from my snow blower but by finding a similar model online. I'm curious if anyone can confirm or negate my assumption, any input is helpful, i know nothing about this.
mike2me is offline
post #4 of 10 Old 10-27-2016, 12:01 PM
Likes (Received): 280
https://www.snowblowerforum.com/forum...-918400-a.html
You can find replacement carbs on ebay cheap... China repops them still. Much better than trying to save a crapped up old one. You need to verify the Engine HP though...... I would guess that one is a 7 HP?
CRAFTSMAN CRAFTSMAN 26 INCH SNOW THROWER Parts | Model 536918400 | Sears PartsDirect
post #5 of 10 Old 10-27-2016, 09:07 PM Thread Starter
Thank you I found a carb and muffler, for a very good price.
mike2me is offline
post #6 of 10 Old 10-27-2016, 10:42 PM
Thanks (Received): 147
Likes (Given): 215
Likes (Received): 305
Glad you were able to figure it out. Are you sure the engine number wasnt 143- 766152? I'm not seeing a -766162
Craftsman Cross Reference
dbert is offline
post #7 of 10 Old 10-28-2016, 07:34 AM Thread Starter
It easily could be the majority of the numbers were very hard to read, im still trying to figure out what i can about this to help find parts, so any info helps, thanks. That cross reference guide was extremely helpful to help find the motor parts i need thank you very much.
mike2me is offline
post #8 of 10 Old 10-28-2016, 08:55 AM
Likes (Received): 345
I assume it looks similar to the one on the right except for being a 3 stage:
I should have a manual that can help you out. I don't think I have for that exact machine but a number of models are virtually identical except for color and minor items. Send me a PM with your email and I'll try to get something out this weekend.
Paul
PS unless you have one with the bronze bushings on the auger and axel, you may want to check out the thread I did on converting to roller bearings. I've done a number of similar machines to the one I've noted.
HCBPH is online now
post #9 of 10 Old 10-28-2016, 04:18 PM Thread Starter
now that you mention it i checked and i do have brass bearings on mine. Any chance you know of a place to get a set of wheels, i need atleast one rim.
mike2me is offline
post #10 of 10 Old 10-28-2016, 09:16 PM
That's good you have the bronze bushings, they're not easy to find the clamshells that hold them in (if not impossible). You can get new bushings but not the clamshells except from a salvage machine if you can find them. On wheels, I've bought a couple of units minus engines just for parts or there's a place that does repairs that occasionally has one with suitable wheels. Put the word out at those local shops, see what they have.
I do have a pdf of the manual for a 536.918300 which is a 7 hp 2 stage that would cover most everything you'd need except it doesn't show the 3d stage parts, but that's pretty much self-explanatory. If you want it, send me an email address. It's about 2.5 mb in size.
Paul
HCBPH is online now
