1997 926 Drive belt slack - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-12-2018, 03:14 PM Thread Starter
I've just replaced the belts on my 1997 926TE, However the drive belt is very slack around the idler pulley and it won't drive the friction plate. I suspect that there should be a tension spring somewhere to pull the pulley into place and tension the belt but I cannot locate it or where it should fit. I bought the blower 2 winters ago without an operators manual so any tips will be appreciated.
Northern Scot is offline
post #2 of 5 Old 01-12-2018, 03:36 PM
Likes (Received): 302
look
post #3 of 5 Old 01-13-2018, 10:37 AM Thread Starter
Thanks for the diagram it helped solve the problem. I had routed the drive belt incorrectly round the idler pulley (rookie mistake!). Once I had routed it correctly it worked perfectly.
post #4 of 5 Old 01-13-2018, 03:11 PM
Thanks (Given): 28
Likes (Given): 157
Likes (Received): 38
Glad you got it going.
Troy-Bilt Storm Tracker 2890
jonnied12 is offline
post #5 of 5 Old 01-13-2018, 03:31 PM
22589
Likes Grunt liked this post
