interesting modded pro 36 - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 11-16-2018, 10:40 PM Thread Starter
Found this little ''gem'' in my local classfield, what you think about the mod?
ID:	148607   Click image for larger version
ID:	148609   Click image for larger version
ID:	148611   Click image for larger version
Name:	Sans titre.png
Morphector is offline
post #2 of 7 Old 11-17-2018, 08:06 AM
Thanks (Received): 341
Likes (Received): 1095
What is trying to with it anyway??????
post #3 of 7 Old 11-17-2018, 08:19 AM
Thanks (Given): 88
Thanks (Received): 174
Likes (Given): 68
Likes (Received): 404
A lot of work for what benefit? To be able to change the auger speed? You can do this by changing the pulley size. Maybe it's a variable speed auger? More things tho go setting with out. If I did this, I would have done it with a much older machine in case it didn't work out.
post #4 of 7 Old 11-17-2018, 10:16 AM
Thanks (Received): 332
Likes (Given): 148
Likes (Received): 749
I dont understand this at all..
I cant tell what the modification is supposed to be doing.
I looked up the actual ad:
https://www.kijiji.ca/v-souffleuse-a...ationFlag=true
The english translation only says:
Biggest Ariens snow blower.
Ariens Polar Force 420CC Engine By Briggs And Stratton.
120 volt electric start with recoil backup.
200 Degree Turn Radius Quick Turn Chute
Single lever adjusts direction and height of snow stream
Handwarmers
Modified with an industrial gear box with heavy duty chains.
That doesnt explain it!
If it creates a variable speed auger..why?
why would anyone want or need that?
very strange..
post #5 of 7 Old 11-17-2018, 10:23 AM
Likes (Given): 148
Full size photos from the ad:
The complete description from the ad:
Souffleuse Ariens Pro”36”-Ariens Pro 36 snow blower.
$1,600.00
Posted 3 days ago
Morin-Heights, QC J0R 1H0
Description
SOUFFLEUSE ARIENS PRO 36
Ariens Pro 36 pouces en excellente condition.La série professionnelle des souffleuses Ariens est définitivement la plus robuste et la plus performante de tous l'industrie.
Moteur Briggs and Stratton 420cc de 15hp.
Poignée chauffante.
Rotation de chute rapide.
Démarreur électrique.
Modifie avec un différentiel en acier industrielle avec des chaines pour etre plus robuste.
Ariens Pro (36") 420cc Two-Stage Snow Blower
Handwarmers
Thats everything we have to go on!
can anyone solve this mystery?
post #6 of 7 Old 11-17-2018, 10:56 AM
Thanks (Given): 19
Thanks (Received): 47
Likes (Given): 102
Likes (Received): 215
He got rid of the auger belts and replaced with chains? Guess the mod didn't work as planned, maybe the reason for selling it? Mental genius.
russ01915 is offline
Likes aldfam4 liked this post
post #7 of 7 Old 11-17-2018, 02:56 PM
Thanks (Given): 509
Thanks (Received): 679
Likes (Given): 3830
Likes (Received): 1472
Maybe he didn't have access to the dual belt mod and he was having a problem with it slipping on him constantly and burning up belts or he "ate" something that took out the auger gearbox and he had this gearbox laying around and decided to get creative ??
It just seems like way more work than what properly curing what might have been the problem would be.
Just trying to figure out how he thinks someone is going to spend 1,200 US on it ??
