Toro 1132 in the U.P. for $250 - Snowblower Forum : Snow Blower Forums
post #1 of 38 Old 06-14-2016, 09:37 PM Thread Starter
Thanks (Received): 238
Likes (Received): 608
Is this worth a look? If nothing else, Muldoon's has great pasties, so it might be worth a drive to look at it.
Toro 1132 Snowblower
post #2 of 38 Old 06-15-2016, 11:46 AM
Thanks (Given): 72
Thanks (Received): 399
Likes (Given): 184
Likes (Received): 932
If you are into vintage Toros, that one looks really nice..
and its big too!
I would say $250 is a good deal..
post #3 of 38 Old 06-15-2016, 03:29 PM
Thanks (Received): 87
Likes (Given): 57
Likes (Received): 269
Ditto! Go get it!
GoBlowSnow is offline
post #4 of 38 Old 06-16-2016, 12:26 PM Thread Starter
I gave them a call and left a message. We'll see if they call back.
post #5 of 38 Old 06-16-2016, 01:53 PM
Likes (Received): 280
Yeah - built like a tank...... nice one.
post #6 of 38 Old 06-16-2016, 07:42 PM
Thanks (Given): 591
Thanks (Received): 773
Likes (Given): 4374
Likes (Received): 1743
Nice and clean for it's age. Let us know how the haggling goes.
post #7 of 38 Old 06-17-2016, 07:30 AM Thread Starter
The lister called me back and I'm going to go look at it Monday. Since he says the price is firm, I don't imagine there will be a lot of haggling.
Thing is, much as I dislike the idea, I'm going to be putting my old Suburban with it's snow thrower attachment up for sale. My dream is to get down to one tractor that does it all, and more than the ones I have now can do. Right now I have the Suburban that I've used to move snow, and a Honda H4514 that I use to mow with. This Toro would be a replacement for the Suburban until I find that dream machine to replace everything with. My HS622, that I really like and that works great on my city drive, might not be the best choice up north on a big gravel drive. I don't think I want to spend the time it would take clearing with the little 22" Honda so it's most likely going to be going up for sale too.
post #8 of 38 Old 06-20-2016, 07:14 PM Thread Starter
Well, I went and looked at it. There was one obvious thing about it that was different from the manual I had looked at. It is supposed to have two levers, one on either handle, that act as safeties. If it is in gear or the auger is running, you have to have your hand on at least one of those levers. If you let go of both, it is supposed to shut down.
The lever on the right is missing, and the one on the left has been taped so as to imitate the presence of an operator.
Anyway, other than that, it started right up on the first pull and all the functions worked as they should, though a little stiff.
He said he was firm on the price of $250 in his ad. I offered $200. He countered with $225 and said he had received four calls on it after I called. Hmmm....time to pull the old I have to check with the wife card.
After some more discussion he said he'd take $200.00 so we loaded it up.
Boy, this thing is heavy! After I got it home and with some effort got it out of the truck, I began giving it the once over to really see what it needs.
So, it has a new home and a list of needed belts, oils, nuts and bolts is being composed.
Pictures and follow up later.
Likes Zavie, classiccat liked this post
post #9 of 38 Old 06-21-2016, 12:37 PM
Likes (Received): 1384
MAZEL TOV on that 1 there. BROTHER U.P. LETS me know if you need any help with it.
post #10 of 38 Old 06-21-2016, 05:36 PM Thread Starter
Thanks buddy. It seems that other than a few adjustments that were a bit out of whack, and that missing safety thing, there were only two other things I found that need, or needed attention. If anybody has a line on the interlock levers, springs and all the assorted stuff that goes with that system, let me know. I'd like to get this part of it back into operation
There were two of those bolts with the square heads on them, the kind that are usually used to hold a pulley in place, laying loose in the bottom of the belly pan.
The other thing that really needs to be taken care of is a spring that is supposed to be attached to the shift lever. Not only would it help keep tension on the drive wheel, it is supposed to pull this thing out of reverse when you let go of the shift lever. Without it, it stays in reverse and could run your hind end over if you were to trip while backing up. Another good reason to have those safety interlock switches functioning. I learned that this thing will try to climb almost anything that comes in its path today. The spring is on order.
I accidentally separated the tractor from the auger section today while changing the belts. Darn thing weighs in somewhere around 300 pounds according to the owner's manual, and getting it to sit just so like the manual suggests while changing the belts isn't easy. But in the process, I found where those two bolts were supposed to be. They came from the auger pulley, and are now safely and tightly back where they were intended to be.
So, the belts were really in need of being replaced. The drive one especially because it was starting to split badly and the auger belt showed some pretty good signs of wear too. I have a new spark plug, but right now my socket for that size isn't here. One of those is on my list to get too. 48 oz of fresh engine oil to replace the old black stuff that was in it, which wasn't near 48 oz. Fresh oil in the gear box. A general go over to see if anything else was missing or not as it should be.
It did have electric start, but somewhere along the line somebody overheated it, so it's toast.
It needs some more clean up from oil that looks like the owner spilled time and time again when filling it. It's all down the front of the engine, around the pulleys, and pooled in the belly pan.
Pictures will be coming when I've got it all back together and cleaned up.
