How to clean right after use? - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-11-2017, 04:12 PM Thread Starter
Been using my new Briggs 24"dual stage, and looks like another storm coming to NE tomorrow.
Right after I was finished, I brought into unheated garage, cleaned off snow.
Then after it was dry (or mostly) wiped down with a rag so there was no sitting water.
Then sprayed Liquid Wrench Heavy Duty Silicone Spray Lube (has SB pic on front) on all metal parts to help prevent rust and keep lubed.
Am I missing anything?
This is just the post storm routine - not end of season. That will be more involved.
Am I hitting all the right bases?
flash4o is offline
post #2 of 15 Old 02-11-2017, 04:33 PM
Thanks (Given): 11
someone mentioned in another thread about using a product called Fluid Film (from Lowes) as a coating and rust preventative...I'm going to look into this myself
Ariens 24 Platinum model 921050 with Poly Shoes
Sold my 17 yr old John Deere 828D for $300 in Jan 2017
outrag1 is offline
post #3 of 15 Old 02-11-2017, 04:47 PM Thread Starter
I grabbed a can of this, too. Just happened to use the other stuff first.
flash4o is offline
post #4 of 15 Old 02-11-2017, 04:52 PM
Thanks (Given): 197
Likes (Given): 197
Likes (Received): 10
I use a Propane Construction Heater, and a Propane Catalytic Heater to defrost the machine . Wiping and lubing is good, but the real issue is removing what you can't see, like ice build up in Transmission Drive, Auger Housing, Recoil Starter and so on.
Over the years, I've seen many Electric Starters aquire Bent Armatures when the Operator tries to start an iced up machine .
During severe cold, I use the heaters to pre - heat the machine so the lubricants flow freely.
Fat City is offline
post #5 of 15 Old 02-12-2017, 06:34 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
I usually just put the snowblower back in the garage and go inside. The snow melts eventually, since the garage maintains about a 40 F temperature.
I am wondering if spraying the machine with WD would attract added dust/dirt over time.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #6 of 15 Old 02-12-2017, 07:04 AM
I still think the best thing you can do is brush off what you can and park the bucket on a rubber truck mat so when it does melt it's not sitting in the water. I use a cheap truck mat because there stiffer unlike the nicer weather tech ones that stay pliable. This channels the water away from the bucket and the stiffness of the mat won't allow the ridges to buckle under the weight.
1996 MTD 5/22
2016 Toro 721 QZR
DuffyJr is offline
post #7 of 15 Old 02-12-2017, 08:24 AM
Thanks (Given): 7
Likes (Given): 9
Likes (Received): 8
I use fluid film as a recommendation from my dealer. Wait until the whole unit is dry and then coat everything orange, and then any springs, the auger, axles...everything. Unfortunately it smells like crap but I'm told that the rust inhibitor capabilities are like no other.
As far as immediate cleaning and drying I don't do anything to my unit. It stays a little frosty until the garage warms up with ambient air. In the spring I'll give it a wash down.
https://www.lowes.com/pd/Fluid-Film-...icant/50335157
2018 Ariens Hydro Pro EFI 28" #313 926068 - FOR SALE
2017 John Deere x758 w/54" HC mower, 14bu powerflow, 4-way QH, 54" blade, FM dethatcher, 18 steel cart
2017 Ariens 24" Platinum SHO EFI 921053 - sold
nastorino is offline
post #8 of 15 Old 02-12-2017, 09:48 AM
Location: Lake George new york foothills of the Adirondacks
Likes (Received): 19
I bought some fluid film and used it on my new machine,and it didn't stop the snow from sticking to the auger and inside the the chute,but I only used it once(because I dropped the can and broke the sprayer tip off) also I agree it does stink,not like wd-40,or any silicone spray.more like rotten grapes.or something like that.
2017 Ariens 24 deluxe 921045
2005 Ariens 8526 932105(sold)
Ariens ss522 (sold)
ih8thepackers is offline
post #9 of 15 Old 02-12-2017, 10:38 AM
Likes (Given): 215
Likes (Received): 304
I just found this discussion on what appears to be a home-brew with lanolin similar to Fluid Film.
Rust prevention with Lanolin
dbert is online now
post #10 of 15 Old 02-12-2017, 11:58 AM
I use an old car brush and clean the snow off most everything. I generally follow that with a light coating of Teflon spray on the augers, the impeller, inside and outside the bucket and anywhere else snow may accumulate on metal as it makes cleanup super quick next time, you can brush most of it away with your hand. Teflon will prevent water creep in tight spaces so ice cannot form if stored in a cold area or during use.
Fluid film is great stuff but I'd use it more so for long term storage or to lube moving parts as it's very thick rather than an every time after use spray or to reduce snow resistance. Teflon will create a anti-rust moisture barrier, it's been working great on my Yamaha so far this season. Silicon would also work if using it every where on the machine, otherwise I'd use a light rust inhibiting spray for specific targeted areas only. I may pick up a bottle of Dry Coat and try it out: Dry Coat | Rust Prevention | Armor VCI
YAMAHA YS624 |
GregNL is offline
