Blew My Engine (over heated) - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 02-18-2017, 01:00 AM Thread Starter
RAYAR's Avatar
Likes (Given): 103
Likes (Received): 21
Last night (Thursday) while using my blower in windy weather, with snow blowing back over the machine, the cooling air intake plugged up. Keep a close watch on the cooling air intake, that's the pull starter cage. It has vents around it where the flywheel (fan) pulls air through for engine cooling. Mine got plugged with snow and ice blocking the flow of cooling air and before I realized it, the engine overheated. It ran for less than an hour afterwards before putting the rod through the side of the block. I guess I won't have to pull the head off of this engine to service the exhaust valve.
This is my Craftsman 8-25 Trac-Drive. When I bought it, the carb was taken apart and pieces missing. I also bought a parts machine with the same engine, so I just swapped the engine. Looks like I'll be installing the original engine and grabbing the carb off of the blown engine.
I now have my Craftsman 12-32 in service.
~Ray~
~1975 Canadiana 1026 Heavy Duty w/light & limited slip differential (& custom exhaust (need to fabricate manifold), customized impeller housing, removable chute in about 5 sec) (currently out of service)
~ Craftsman 8/25 Trac-Drive C950-52671 (mid 80's ???) (current user) (replaced blown engine with original, now in service again)
~ Craftsman 12/32 OHV 71-52112-1 (now in service)
~Noma GP 1028EL (repaired and serviced for daughter to use)
RAYAR is offline
post #2 of 17 Old 02-18-2017, 01:43 AM
Sorry to hear you lost an engine. Mine was icing up too, but I paused every hour to clear it. It's been a rough couple days in NB hasn't it?
THE Wolfman is offline
post #3 of 17 Old 02-18-2017, 02:55 PM
Thanks (Received): 28
Likes (Received): 67
Thanks for the heads-up! I hadn't given much thought to keeping that area clear for cooling.
New Husqy ST227P for 2014-15 snow season.
I love my snowblower. Every beat of it's little heart is one mine won't have to take.
dr bob is offline
Likes jesdog2, colin.p liked this post
post #4 of 17 Old 02-18-2017, 03:51 PM
Thanks (Given): 587
Thanks (Received): 766
Likes (Given): 4349
Likes (Received): 1734
I keep thinking of the old Simplicity blowers that had a chunk of metal like a hood over the engine. The more I think about it the more it seems to make sense to cover the engine to keep as much snow out as possible. I always worry something is going to freeze the governor open. Problem is it wouldn't help in this case unless you made a removeable panel to cover the pull start after you get it started. That way the air would have to go below the cover and come up. Hopefully dropping out most of the blowing snow. Sorry, just one of those crazy thoughts that get through the tin foil hat.
post #5 of 17 Old 02-18-2017, 04:21 PM
Likes (Given): 1878
Likes (Received): 661
good thing you had another motor but it still sucks just the same
Likes Kiss4aFrog, Sid liked this post
post #6 of 17 Old 02-18-2017, 05:17 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 43
We learn something every day. Thanks for sharing.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
Likes jesdog2 liked this post
post #7 of 17 Old 02-18-2017, 06:30 PM
colin.p's Avatar
Thanks (Given): 8
Likes (Given): 76
Oh man, now that sucks. I want to "like" this posting, but it doesn't seem right. Thanks for the heads up, I'll have to keep that in mind, even though today, the robins are singing and flying all over the place. The snow is melting and even the bleeding chickens are getting pretty ansi (sp?) Must be spring in the air????
2013 Toro PowerMax 826 OE Model # 37772
colin.p is offline
post #8 of 17 Old 02-18-2017, 11:31 PM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
This is a legit concern, especially those that repower winter equipment with summer engines.
drmerdp is offline
post #9 of 17 Old 02-19-2017, 01:54 AM Thread Starter
RAYAR's Avatar
Likes (Given): 103
Yes it has been a rough couple of days in NB. Your air intake can plug up very quickly in heavy blowing snow across the engine, so keep an eye on it in such situations.
~Ray
~Ray~
RAYAR is offline
post #10 of 17 Old 02-19-2017, 10:23 PM
Sorry to hear about the engine going toes up, but thanks for the head up. To be honest, something I wouldn't have thought about.
Bill
BillE is offline
