Looking for help picking a 24" snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 23 Old 03-17-2017, 09:12 PM Thread Starter
I'm looking for a 24" snowblower and was wondering if someone can help me pick the best one for me. I live in Philadelphia and will be using it for my house. My driveway is 12' wide by 45' long if that helps make a decision. I don't want to spend more than $800 and I have been doing a little research on then. I was looking into the 24" Sno Tek made by ariens for $650 and read a lot of good reviews. I also read good stuff on the craftsman 88173 and the husqvarna ST224.
MikeyDubs is offline
post #2 of 23 Old 03-17-2017, 09:40 PM
I can only speak to my new purchase this season -https://www.amazon.com/Briggs-Stratton-1696619-Dual-Stage-Electric/dp/B00VCM00UU/ref=s9_simh_gw_g86_i1_r?_encoding=UTF8&fpl=fresh&p f_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=PB31M9RGMNAJ 3PB84E4E&pf_rd_t=36701&pf_rd_p=1cded295-23b4-40b1-8da6-7c1c9eb81d33&pf_rd_i=desktop&th=1
Got for $750 from local dealer. Amazon reviews are very good. My experience has been excellent. Starts on first pull, lots of power, and very, very quiet, and nice controls.
Hopefully helps with your research.
flash4o is offline
post #3 of 23 Old 03-17-2017, 09:45 PM
Likes (Received): 17
First of all, how much snow does your area get on a average? Is the snow usually heavy and wet or light and fluffy? With the size of your driveway you might be able to get by with a single stage.
The Q is offline
post #4 of 23 Old 03-17-2017, 09:48 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 300
My brother picked up a ST224 when lowes had it on clearance for $699 and he absolutely loves it, good quality and worked very well on the EOD on the one storm he got to use it on, I like Ariens but there priced a little higher so my vote is for the Huskavana, that craftsman number doesn't pull any search results so can not comment
Dauntae is online now
post #5 of 23 Old 03-17-2017, 10:41 PM Thread Starter
Ok I will look into that blower. Thanks!
Usually around 6" fluffy and sometimes wet but we also get hit with big blizzard here and there.
Ok that's good to know. thanks!
post #6 of 23 Old 03-18-2017, 08:24 AM
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Check out the toro snow masters. There are a few members here that own them and love them. Check them out on youtube, lots of real people with great reviews. With your size drive way it would be perfect.
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
post #7 of 23 Old 03-18-2017, 09:14 AM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
A snowmaster would be sufficient for your location and size driveway.
If 2 stage is in your future, I suggest a
Toro powermax 724
Ariens compact 24.
Both are at your budget.
But for a few hundred more you can have yourself a Ariens deluxe 24 which i think is a better value.
drmerdp is offline
post #8 of 23 Old 03-18-2017, 09:31 AM
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
There's a lot of things to look at when buying a new blower.
The new engines have steel tanks with no shut off valves, the exit is inaccessible to drain so all end of season draining or carb repairs you must drain through the fuel bowl. The engines are more difficult to get to to repair.
I don't like some of the cables and how they connect, wind around, and the path they follow.
There was a post recently that someone was having problems getting parts for their Chinese engine.
I live across the river from you and for most storms a 5hp machine is fine, even for 24" snows, but they fail after the plows come by and pack the snow, now you are left shoveling. A 5hp also fails or does not do well on really wet snows clogging the chute constantly. This recent snow I started using my 5hp snowblower and it was slow going with clogging besides not throwing it far enough across the drive. I have 2 5hp, 2 8hp, and 2 10hp, all ready to go, plus a 12hp. I put the 5hp away, skipped over the 8hp, and pulled out the 10hp and absolutely no problem. The chute started to clog a number of times as I did mine and 5 neighbors, nothing was coming out, then boom, it blew, and because it was so wet, I could hear and feel the pounding in the chute, in as the wet snow went through the metal chute, it was a loud steady bang, bang, bang as the snow went through in these large packed cylinder pieces, they looked like packing charges for a cannon. All the neighbors that were using a 5hp were looking at me moving along at a good clip, or being frustrated clearing the chute. One gave up and called me to do their driveway and sidewalk. When looking at horsepower, think of this.
A 10hp is a overkill for you but a 8hp would not be, in either 24" or 26".
post #9 of 23 Old 03-18-2017, 10:50 AM
Thanks (Given): 178
Thanks (Received): 344
Likes (Given): 482
Likes (Received): 851
I've seen good feedback on the Toro Snowmasters so far, though they are new, and reliability is unproven. They sound more capable than a typical single stage, but quicker and easier to handle than a 2 stage.
For any machine, it's always nice to have a little extra power, vs not enough. But the need for that depends on budget, type of snowfall, driveway size, and how much time/patience you have
A 5hp machine will still clear most storms, but you may have to slow down a bunch (narrower cuts, slower ground speed). An 8hp/10hp will have an easier time, and can go quicker.
I have yet to regret having too much power available
post #10 of 23 Old 03-18-2017, 12:46 PM
My new Briggs engine does indeed have fuel shut off valve.
flash4o is offline
