Engine Swap - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 03-24-2017, 06:14 PM Thread Starter
Engine Swap
Hi everybody,
I have a 1987 Toro 521 with the HS50 Tecumseh engine that I'd like to replace with a newer one or one barely used. My question is what Tecumseh engine that isn't the identical model to my old one would fit my snowblower?
The engine I currently have is #HS50 67259F and it's 5 horsepower.
I have seen used 5.5 horsepower Tecumsehs that have the LH designation.
***Would an LH fit?
They all look like they have the same mounting holes as my old engine but wonder if there would be any other problems?
***If an LH wouldn't fit, would an HSSK 50 fit fine?
I know I'd have to have a 3/4 shaft and 3/8 shaft screw on the newer replacement engine to fit the original pulley (which I don't want to replace) on the blower.
Thanks for the help,
Rich
Rich Speers is offline
post #2 of 17 Old 03-24-2017, 07:27 PM
Thanks (Received): 195
Likes (Given): 469
Likes (Received): 816
Any Tecumseh 5-6-7 hp engine will be a direct Bolt On Replacement, as long as it has the same size Crankshaft Diameter. Easy Peasy.
Jackmels is offline
post #3 of 17 Old 03-24-2017, 07:38 PM Thread Starter
Thank you!
post #4 of 17 Old 03-24-2017, 08:20 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 147
Likes (Received): 297
Also you have to make sure it's not a double shaft engine, If so the replacement will need to be also. Tecumseh came with single and double shaft.
Dauntae is offline
post #5 of 17 Old 03-24-2017, 09:06 PM Thread Starter
Thanks!
post #6 of 17 Old 03-24-2017, 09:34 PM
Likes (Given): 469
521 is a single shaft application. Any 5-6-7 Tecumseh with the same size crank will work, even a double shaft, You just don't use the PTO, and cut off the secondary shaft if it is in the way of the belt cover.
Jackmels is offline
post #7 of 17 Old 03-24-2017, 09:47 PM Thread Starter
Good to know, thanks. I'm glad it sounds like almost any used Tecumseh should bolt on without any issues. I do not want a Predator which I feel has just the cool name going for it and I grew up USA/German or Japanese products only. I want something with real steel in it but unfortunately those days are about extinct so I'm going used and in good shape.
post #8 of 17 Old 03-24-2017, 10:09 PM
Likes (Given): 469
You should post Your Location. Someone Here might have an Good Engine Available Locally.
Jackmels is offline
post #9 of 17 Old 03-24-2017, 11:29 PM
Thanks (Given): 13
Likes (Given): 147
Are you sure Jack, Not positive but I thought the one My girl has was a double shaft, I may have been thinking of another blower but I thought it was hers. I'm going to have to check on that one.
Dauntae is offline
post #10 of 17 Old 03-24-2017, 11:34 PM
drmerdp's Avatar
Thanks (Received): 149
Likes (Given): 24
Likes (Received): 308
The honda clones (predator to name one) are arguably better engines then tecumsehs. Its nice to know that tecumseh was made in america though.
Definitely a simple swap from one tecumseh to another small frame tecumseh.
drmerdp is offline
Likes 43128 liked this post
