Ariens disappointment - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 06-13-2017, 02:20 PM Thread Starter
jermar's Avatar
Thanks (Received): 14
Likes (Received): 14
My 2016 Compact 24 was used perhaps five times over the last two winters. I like to keep my equipment looking like new. A couple of days ago, I pulled it out to change the oil. I was disappointed to see the shaft going from the auger to the impeller was covered in rust. Some of the nuts & bolts on the machine are showing early rust as well. I sanded the shaft, applied two coats of silver "Rust Bullet" and finished with Por 15 topcoat black. I always rinse the bucket after each use in case it was exposed to salt. I'm a little bent that I have to do this for a nearly new machine. Okay, I've vented.
jermar is offline
post #2 of 12 Old 06-13-2017, 03:53 PM
Thanks (Received): 379
Likes (Received): 1377
First law of metal, IT ALWAYS RUSTS. it is returning to it's original state. you could have the finest german, british steel and it will do the same thing.
post #3 of 12 Old 06-13-2017, 05:16 PM
Thanks (Received): 34
Likes (Given): 28
Likes (Received): 72
Welcome to the age of cheap steel and cheaper paint (read eco-friendly into that). My '63 SnowBird still has most of its' paint on the impeller shaft. Sign of the times brother.
DriverRider is offline
post #4 of 12 Old 06-13-2017, 07:23 PM
524SWE's Avatar
Likes (Received): 23
probably another example of poor prep before paint. that coupled with the "new" EPA paints with no lead and less volatile solvents and chemicals in their formula just don't have the longevity of yesteryear.
1995 Toro CCR1000
2007 Cub Cadet 524SWE
524SWE is offline
post #5 of 12 Old 06-14-2017, 03:23 PM
Thanks (Given): 10
Thanks (Received): 15
Likes (Received): 17
Agreed, what a shame. I would not buy a new machine if I had to. Now I'm always looking for older lightly used machines over the new crap, your almost always better off with an older lightly used machine over new now. They don't build anything like they used too. It's a shame.
FearlessFront is offline
post #6 of 12 Old 06-14-2017, 06:06 PM
Thanks (Received): 212
Likes (Received): 767
my thought....get a 70's or 80's Ariens.....get rid of the Tecumseh ...install a preditor from HF...AND LET THE GAMES BEGIN!
cranman is offline
post #7 of 12 Old 06-14-2017, 07:35 PM Thread Starter
jermar's Avatar
Good points about cheap steel & cheaper paint. All that orange paint is rust free and so is the auger. That shaft is visible, so I'd be happy to pay the extra buck it would take to paint it with something that lasts.
jermar is offline
post #8 of 12 Old 06-15-2017, 01:35 AM
E350's Avatar
Thanks (Given): 280
Thanks (Received): 62
Likes (Given): 159
Likes (Received): 77
Valspar Tractor and Implement Enamel (in the can) and add the Valspar 4625 Enamel Hardener both on Amazon. And read and follow the precautions including using a 3-M replaceable filter respirator.
E350 is offline
post #9 of 12 Old 06-15-2017, 10:08 AM Thread Starter
jermar's Avatar
Thanks E350. I did use Valspar 4625 Enamel Hardener with POR15 topcoat. I love 4625. I'm about to use it to paint a garage side door along with my favorite paint: Rust-Oleum Marine Topside Paint. [Also on Amazon.]
jermar is offline
post #10 of 12 Old 06-17-2017, 01:08 AM
E350's Avatar
Thanks (Given): 280
Likes (Given): 159
Jermar:
Marine Coatings Topside Paint Product Page
Based on your recommendation, I am willing to try it with the Valspar Hardener. What do you prefer in the Rustoleum Topside Paint over the Valspar Tractor and Implement?
And do you thin the Topside? and if so, with what?
Thanks in advance.
E350 is offline
