Toro 524? - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 09-05-2017, 03:06 PM Thread Starter
Toro 524?
Hello. I have a new driveway that is about 200 feet long, with the last 50 on a moderate slope. I'm hoping to avoid spending $500+ yearly on snow plowing. There's a used Toro 524 on Craigslist that looks on first glance like it's in pretty good shape, and only $150. Could that be powerful enough? In western Massachusetts, so anywhere from a couple to 6 or 8 significant storms a year (say, 6 - 20+"). I suspect it's too small a machine, but the price sure is right.
Alternatively: What would be a big enough machine for this purpose, and roughly how much should I expect to pay for one used? I may well be selling the house next summer, and money is tight, hence the search for an effective but inexpensive way to do this.
Thanks!
danielsomers is offline
post #2 of 4 Old 09-05-2017, 03:51 PM
Likes (Received): 1383
IT will have the Rasins in it for the 6-12 stuff. but if you should get 1 of those nor'easters either you will be working it like a rented mule. or you could call upon MR Plow for help. if the frame is in good shape but if the motor is getting tired you could put 1 of those Preadtor engines on it with out to much trouble. then you can go full bore on in one of those Nor'easters. Anyhoo ALOHA from the Paradise city.
post #3 of 4 Old 09-05-2017, 05:03 PM
Thanks (Given): 37
Thanks (Received): 70
Likes (Given): 116
Likes (Received): 146
Yeah, I think the 5/24 might be on the small side. Wet snow will certainly put a 5hp motor to the test. If it were me, I would look for something with at least 8hp and 24" bucket. Given that you have a moderate slope, I would also lean toward a machine with chains on the tires.
What about this Toro 824 in Belchertown?
https://westernmass.craigslist.org/g...291256020.html
If the machine is in good shape maybe get him down to $250 range. Should be perfect for your needs.
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is offline
post #4 of 4 Old 09-05-2017, 05:15 PM
The POWERSHIFT would be a better choice for that.
