Need help with my snowblowerLED upgrade project - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 12-19-2017, 05:28 PM Thread Starter
I'm trying to upgrade my halogen snowblower light to LED.
I put together my wiring as described on this forum: snowblower power source --> switch --> rectifier --> two 2200uf 50v capacitors --> 18w LED light. I connected it to my snowblower, and nothing!
As a test, I connected the wiring to a 12v battery and the light worked. My voltmeter shows 12.5v from the battery and 12.1v after the capacitors. So my wiring seems fine to me; why doesn't it work when connected to the snowblower?
abjman is offline
post #2 of 22 Old 12-19-2017, 09:18 PM
69ariens's Avatar
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Bad ground?
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
Likes blizzard hater liked this post
post #3 of 22 Old 12-19-2017, 10:02 PM Thread Starter
Originally Posted by 69ariens View Post
Bad ground?
For test purposes I grouped my ground wires and attached them with an alligator clip wire to the engine block ground nut.
abjman is offline
post #4 of 22 Old 12-19-2017, 10:21 PM
Likes (Given): 7
Likes (Received): 8
"For test purposes I grouped my ground wires and attached them with an alligator clip wire to the engine block ground nut."
That's most likely your problem. You shouldn't ground anything to the chassis/engine block. Take your source and connect it to the circuit, after that ground nothing directly to the blower. This should fix your problem.
alylea is offline
post #5 of 22 Old 12-20-2017, 12:50 PM
Keep in mind that some stators do NOT have a reference to frame ground. I realized this on my machine when upgrading my stator. My OEM one was a half moon and one half of the windings was grounded to the frame. My new stator did not have a reference to the frame. It was floating VAC. You may want to check that. My posts give some more detail.
https://www.snowblowerforum.com/forum...4-post993.html
https://www.snowblowerforum.com/forum...8-post995.html
Bassguitarist1985 is offline
post #6 of 22 Old 12-20-2017, 08:42 PM
Thanks (Given): 21
Thanks (Received): 64
Likes (Given): 254
Likes (Received): 248
LEDs are polarity sensitive, most of the time. They use BLACK as hot and WHITE as GROUND. Check that out. And go right to the rectifier don't ground to the engine.
jsup is offline
post #7 of 22 Old 12-21-2017, 06:22 PM Thread Starter
I took the suggestions from this thread and hooked up the (-) wire from the LED to the DC- coming from the rectifier. I also hooked up the AC- from the rectifier to the blower's ground wire. Nothing. Detached the AC ground wire, still nothing. I've triple-checked my wiring and everything seems correct.
I reattached the halogen light, and it works so I know I'm getting power.
Any more suggestions? The solution is probably staring me right in the face and I just don't see it.
abjman is offline
post #8 of 22 Old 12-22-2017, 11:33 PM
Thanks (Given): 21
Likes (Given): 254
Start from the beginning... make sure you have 12v AC going into the rectifier. Then make sure there's 12V DC coming out.
jsup is offline
post #9 of 22 Old 12-27-2017, 10:36 AM
If you have 12VDC or so coming from the BR (Bridge rectifier) then it should work, you may simply have the LED polarity crossed. If you have black/white wires, I've seen it both ways, Black is (-) and white (+) and the even black (+) and white (-). LED's are polarized so I would try switching the leads, the worst case scenario is if its a decently made LED and the polarity is wrong, it simply won't light.
post #10 of 22 Old 12-27-2017, 03:24 PM
Thanks (Given): 28
Likes (Given): 157
Likes (Received): 39
Don't ground the DC coming out of the Bridge Rectifier. The Bridge Rectifier has Pos. and Neg. terminals. Connect those DC wires directly to the LED wires (with the capacitors wired between the two wires, of course).
No external ground after the Bridge Rectifier - ever.
Borrowed from KissaFrog:
Troy-Bilt Storm Tracker 2890
jonnied12 is offline
Thanks Bassguitarist1985 thanked for this post
