$150 Craigslist snowblower vs. 2ft of lake effect snow - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 12-27-2017, 02:30 PM Thread Starter
Hey guys,
So I picked up this blower on Craigslist after my MTD 12/33 busted a shearpin and upon inspection needed more TLC than a shearpin. When I picked it up it would stall anytime it got a load on it. I brought it home and changed the oil and cleaned the carb and it's been running good ever since. I still prefer my MTD for the wider cutting width as well as the taller intake which would have come in handy for this latest storm. Overall though this Craftsman got the job done. It took 4 hours and two tanks of gas.
ID:	120841   Click image for larger version
bizzo15 is offline
post #2 of 14 Old 12-29-2017, 08:16 PM Thread Starter
Pic for reference
bizzo15 is offline
post #3 of 14 Old 12-29-2017, 08:37 PM
Thanks (Given): 89
Thanks (Received): 175
Likes (Given): 68
Likes (Received): 406
Looks like mine, a 1995 Murray built Craftsman 10hp 29" width. It's a strong machine, just pounds the snow out. Though I find holding the levers down is uncomfortable so I use a plastic spring clamp for the auger lever.
post #4 of 14 Old 12-29-2017, 09:03 PM
Thanks (Given): 56
Thanks (Received): 62
Likes (Given): 51
my 80"s craftsman 10/28 my auger hand was aching to keep the lever down. realized i had the tension to tight, loosened it up so auger still engages , but got to wait for more snow to test it out
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #5 of 14 Old 12-29-2017, 09:13 PM
jrom's Avatar
Thanks (Given): 342
Thanks (Received): 106
Likes (Given): 1033
Likes (Received): 175
Originally Posted by bizzo15 View Post
...I brought it home and changed the oil and cleaned the carb and it's been running good ever since.
For $150...if it continues to hold up for you...it doesn't get much better than that!
Good going.
Honda HS828TAS (1991) – Made in Japan with Thai built GX240
Honda HSS1332ATD (Late-2015) – Made in USA with Thai built GX390
180" to a rare 350" of snow per year (Alberta Clippers & Lake Michigan), 644' gravel driveway, 2 vehicle parking areas, 500' of trails around small house with an unheated garage.
jrom is online now
post #6 of 14 Old 12-29-2017, 10:18 PM
aldfam4's Avatar
Thanks (Given): 201
Thanks (Received): 40
Likes (Given): 568
Likes (Received): 108
Hey guys,
Nice find!
aldfam4 is online now
post #7 of 14 Old 12-30-2017, 12:56 AM
solsun's Avatar
Likes (Given): 14
Likes (Received): 8
Impressive! Two tanks of gas and four hours? Sounds like Miller time to me!
solsun is offline
post #8 of 14 Old 12-30-2017, 01:51 PM
Thanks (Received): 139
Likes (Given): 14
Likes (Received): 326
Sounds like you got it for a decent price, it did the job and is a lot easier than shoveling. Sounds like a win-win to me.
Congrats.
HCBPH is offline
post #9 of 14 Old 12-31-2017, 07:21 PM
Thanks (Received): 53
Likes (Given): 105
Likes (Received): 72
I can't tell from the pic. Is that a 28" wide bucket? Tecumseh engine? HP?
The bucket does look a bit low in height. YOu could use some drift cutters. Does not look as though there are any hole to mount them but you could easily drill some.
In any event a great deal for 150! Good Luck!
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #10 of 14 Old 12-31-2017, 09:04 PM
Likes (Received): 41
what great lake are you by bizzo?
topher5150 is offline
