Snowblower modifications - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 12-28-2017, 07:43 PM Thread Starter
So Iím hunting around Helena Mt for a broken snowblower just so I can try some of my ideas. I am curious about changing the impeller or adding additional impeller to increase top speed and volume. Like a two stage pump.
My other idea is replace the auger with heavy bristles like off a power broom. It would be tricky to have enough scarifying effect but not too much to damage driveways. The end goal would be breaking up the packed ice on driveways that typically stops a blower.
People talk about pulley swaps but what about a small snowmobile clutch. Yes it would be hard to fit in the housing and a pita to get the weights right. But that gives optimum rpm for the fan based on the load. The more snow in the bucket the lower the rpms are, that would allow a higher pulley ratio as the clutch closes and gives more torque.
Guess I have a lot of free time and maybe someone out there has tried some mods and not posted about them.
Nbjornstad is offline
post #2 of 17 Old 12-28-2017, 07:55 PM
Thanks (Given): 224
Thanks (Received): 294
Likes (Given): 1857
Likes (Received): 648
I think the brushes might pull too much snow into the housing for the impeller to handle regardless to how many blades the impeller has
post #3 of 17 Old 12-28-2017, 08:14 PM
Thanks (Received): 34
Likes (Given): 28
Likes (Received): 72
The determining factor of snow input to the bucket is width and ground speed. Augers channel snow inwards to impeller so conventional brushes rotating on an axis could not easily do that. Brushes have their place in snow removal already.
DriverRider is offline
post #4 of 17 Old 12-28-2017, 08:27 PM
Thanks (Given): 224
Likes (Given): 1857
back in the very early '70's we had a snow removal service with brooms like that mounted on jeeps. would you do away with the chute if you mounted a broom
post #5 of 17 Old 12-28-2017, 09:02 PM
Thanks (Given): 21
Thanks (Received): 64
Likes (Given): 254
Likes (Received): 248
Simplicity does what amounts to a CVT transmission on the impeller for exactly the reason you cite, keep the machine in the power band.
jsup is offline
post #6 of 17 Old 12-28-2017, 10:47 PM Thread Starter
So another dumb question. So everyone says that the impeller rubber trick is gods gift to snowblowers. A snowblower is limited in forward movement by the snow loading inside the bucket and how fast it is moved and expelled by the impeller/fan. Most fans I have looked at are at 90 degrees. Most industrial fans for moving any slurry looks like a boat prop with 4-5 blades. Would having a canted blade angle increase the feed rate? Would introducing more air flow from the chute and reating a stronger low pressure in the bucket cause more material to move?
Thanks guys I just been lurking in the shadows reading for a long time thinking up questions lol
post #7 of 17 Old 12-28-2017, 10:49 PM Thread Starter
The broom bristles would be mounted to the auger not an actual broom core replacing the auger. That way the bristles sweep the ground and scarify but would be clearenced inside the bucket. That would prevent overloading. Not that I have ever wire brushed ice but I imagine poly wires scratching at ice would have an effect without damaging the concrete surface. Being mounted to the auger keeps it simple and doesnít need an additional rotating assembly.
post #8 of 17 Old 12-28-2017, 11:24 PM
Likes (Given): 28
So another dumb question. So everyone says that the impeller rubber trick is gods gift to snowblowers. A snowblower is limited in forward movement by the snow loading inside the bucket and how fast it is moved and expelled by the impeller/fan. Most fans I have looked at are at 90 degrees. Most industrial fans for moving any slurry looks like a boat prop with 4-5 blades. Would having a canted blade angle increase the feed rate? Would introducing more air flow from the chute and reating a stronger low pressure in the bucket cause more material to move? Thanks guys I just been lurking in the shadows reading for a long time thinking up questions lol
I would not call snow a slurry, more static material. Introducing air to the discharge is a worthwhile endeavor but where does additional air come from another system like a screw driven blower which requires hp? Is this a race as to how far one can throw snow? Most snow removal machines operate within neighborhood confines and I for one don't want my neighbor blowing his snow into my property. In April the only snow left in the neighborhood is on my property, I don't think so.
post #9 of 17 Old 12-28-2017, 11:58 PM Thread Starter
I just daydream about building a better mousetrap. A 2 stage snowblower is pretty much un evolved since itís introduction. The horse was the best thing until the car.
Although amazing to watch how many people need to throw snow 50í? But the faster I move the material the less time I spend in the cold. If you're a contractor you spend less time because the machine does the job more efficiently = more money. I think the fan is the slowest part of the process. Iím just trying to figure a way to improve it. The chute can be aimed down 😉
post #10 of 17 Old 12-29-2017, 12:34 AM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 178
If you want to see the business end of a single stage snow clearer type Beilhack in the advanced search box and look for the picture of the Conrail Beilhack snow clearer in a night shot near Utica with a twin snow clearing disc system using a centrally mounted hydraulic chute and spout
The problem is torque, the lack of it and what the consumer is willing to spend OR NOT SPEND. If you want to see a good snow blower I have pictures of the Zaugg bulldog on the forum and Zaugg also has videos of the snow beast as well working with the bulldog.
Last edited by leonz; 12-29-2017 at 11:22 AM. Reason: stuff/spelling and punctuation corrections
leonz is offline
