Removing Water from Gas Tank in Cold Temp. - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 01-04-2018, 05:01 PM Thread Starter
solsun's Avatar
Likes (Given): 14
Likes (Received): 8
Iím in process of fixing the carb on my (new to me) Ariens 926 LE. I decided to replace the fuel line and empty the gas tank at the same time.
https://imgur.com/a/Ifz5c
When I went to empty the gas tank I noticed water bubbles, which I had expected. After draining the tank, it occurred to me that the water wouldnít evaporate in this cold weather (Metro Detroit is in single digits now). I donít have anywhere warm that I can take the tank to dry off.
I would hate to do all the work of fixing fixing carb and replacing lines to reintroduce water into the system from the gas tank.
Any ideas or thoughts?
Solsun
solsun is offline
post #2 of 20 Old 01-04-2018, 05:06 PM
Thanks (Received): 7
Likes (Received): 8
Sorry if I am misunderstanding, where did the water coming from? How much water is there?
Maybe you can slosh around some fresh gas, then dump it out. The ethanol in the gas (assuming it's E10) should absorb some of the water, if it isn't frozen.
1998 Honda HS621, 1990 Toro 521
EdwardC is offline
post #3 of 20 Old 01-04-2018, 05:11 PM
Thanks (Given): 13
Thanks (Received): 125
Likes (Given): 146
Likes (Received): 286
If it's just some droplets in the tank, Just put some treated gas and fill it all the way up, That amount won't do anything to the carb, Just think how much snow gets pulled through the carb when in use.
Dauntae is online now
post #4 of 20 Old 01-04-2018, 05:24 PM Thread Starter
solsun's Avatar
Likes (Given): 14
Likes (Received): 8
Before I emptied the gas out I could only see small bubble at the bottom of the tank. Itís nothing extreme.
I just bought this machine from a guy that had hardly used it for the past 5 yrs. I assume it picked up some water along the way.
https://imgur.com/a/neYym
solsun is offline
post #5 of 20 Old 01-04-2018, 05:28 PM Thread Starter
solsun's Avatar
Likes (Given): 14
Likes (Received): 8
Thanks. Yeah itís just a few droplets that I could see when I looked in the tank. I guess Iím being too cautious.
Would sea foam do it? I was planning to use ethanol free gas when I fill it up.
solsun is offline
post #6 of 20 Old 01-04-2018, 05:31 PM
Thanks (Received): 207
Likes (Received): 762
Seafoam good......dri-gas better ...use both...just for one time.....
cranman is online now
post #7 of 20 Old 01-04-2018, 05:35 PM
orangputeh's Avatar
Thanks (Given): 744
Thanks (Received): 218
Likes (Given): 1464
Likes (Received): 1458
dry gas? seafoam?
hair dryer? haha
just like someone else mentioned , fill the tank with treated gas and you'll probably be ok.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #8 of 20 Old 01-04-2018, 05:50 PM
Actually I usually just drop the bowl and wipe it out as the water has a tendency to find it's way there and stay....then let the gas flow into a can for a few seconds then button it up. when I'm lazy I put a few ounces of Methanol based dri gas.I know for certain that the ethanol in gas doesn't take out all the water....I'm always fixing tractors that stall from it and won't restart.
post #9 of 20 Old 01-04-2018, 06:03 PM
Thanks (Received): 75
Likes (Received): 238
k100 treatment should do it if you can find some near you. it removes the water from the gas
yardworks 31AH6WKF515
crazzywolfie is online now
post #10 of 20 Old 01-04-2018, 06:06 PM Thread Starter
solsun's Avatar
Likes (Given): 14
Likes (Received): 8
Thanks for your feedback. I think Iím going to flush it a bit and use dry gas.
solsun is offline
