Do any of you install a FUEL filter? - Snowblower Forum : Snow Blower Forums
post #1 of 18 Old 01-05-2018, 03:24 AM Thread Starter
Thanks (Given): 31
Thanks (Received): 14
Likes (Given): 67
Likes (Received): 15
Was wondering if many of you install a filter in the fuel line.... On the more modern units?
I peeked in the tank today and saw a fair amount of fine debris.
I realize the older units would benefit from a filter which dont have the screen under the gas cap area
like the more modern units.
I do it on my bikes and lawn mowers.
so perhaps I may consider doing it when the opp comes around?
PS do any of you ever flush the gas tank?
Ariens Deluxe28+ AX414cc
Ariens ST824
Ariens 1970
Honda HS521
Cub cadet SS
Snowbird
Biketrax is offline
post #2 of 18 Old 01-05-2018, 05:44 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 60
Likes (Given): 131
Likes (Received): 221
No . . . but I am thinking that I should. I am not sure what filtering gets done at the tank fitting or just before the carb bowl. When I looked at the fuel line on my Briggs 305cc it did not seem to have any in-line filter.
I would imagine that a filter would help avoid fuel issues. . . all of my boat engines have filters between the gas fitting and the carb bowl.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is online now
post #3 of 18 Old 01-05-2018, 05:51 AM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
these are gravity fed fuel systems, if using one make sure filter has a high flow rate or u might starve the motor. imo, waste of time, effort, and more troubleshooting if having carb issues. and wont stop ethanol or water issues.
u can try to filter it b4 putting it in by using a coffee filter
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #4 of 18 Old 01-05-2018, 06:47 AM
deezlfan's Avatar
Likes (Received): 30
I don't see adding one as a waste of time. In fact, if you buy a quality clear filter, it can actually become a diagnostic tool. Being able to see what is coming out of the tank or even if something is coming out of the tank can be a benefit. But you are absolutely correct that adding a filter that won't gravity feed reliably is a problem.
There's just one thing I'll guarantee , the best things in life, they sure AIN'T FREE !!
88 Craftsman II Trac-Plus 10/32 [wheeled conversion]
71 Ariens SnoThro 6/24 [Predator 6.5 repower]
72 Ariens SnoThro 6/24 with original Tecumseh H60
7? Ariens Tractor with rotary mower attachment [Tecumseh HSK100 repower]
deezlfan is offline
post #5 of 18 Old 01-05-2018, 06:50 AM
Thanks (Given): 146
Thanks (Received): 325
Likes (Given): 430
Likes (Received): 778
If there's no filter at all, I would definitely install one. My current machine has a screen at the outlet from the gas tank, so I didn't add another filter.
Like vinnycom said, make sure you get a filter that is meant for gravity-fed carbs, not machines with fuel pumps. The gravity-fed-system filters use a looser mesh, so they let tiny things through, but they avoid creating too much of a flow restriction, which would starve the engine for fuel.
This Briggs filter is suitable for gravity-fed machines like blowers, part number 5018K:
post #6 of 18 Old 01-05-2018, 07:07 AM
vinnycom's Avatar
Thanks (Given): 59
Likes (Given): 58
for motors in a dusty environment, yes.
for snowblowers, meh. make sure gas can and tank are clean(ish).
afaik, especially for the older snowblowers, manufactures for decades havent used them.
the biggest problem is people letting gas stay in their machines for long periods of time...and ethanol, now they got to remember to change fuel filter.
i find it odd that theres no air filter, but i understand why not.
imo, ymmv
post #7 of 18 Old 01-05-2018, 07:36 AM
Thanks (Received): 8
Likes (Received): 31
This funnel will also separate water .http://www.amazon.com/Mr-Funnel-AF3C...ds=fuel+funnel
gregg is offline
post #8 of 18 Old 01-05-2018, 08:02 AM
Likes (Given): 7
Likes (Received): 8
Gravity style filters are a very good and inexpensive insurance policy. I added a filler inlet screen and will add an inline filter too. Some machines like CC HD series are being built with metal fuel tanks. Unless you coat/seal them, they will most likely rust or corrode over time and you will have big reliability issues. Of course this will happen during a major storm. Better safe...
alylea is offline
post #9 of 18 Old 01-05-2018, 08:15 AM
oneacer's Avatar
Thanks (Received): 140
Likes (Received): 510
Those little cheap red round ones, like what Briggs sells (previous photo), has the small screening, enough to let fuel flow in, yet keep debris out ...
oneacer is online now
Likes Cold1 liked this post
post #10 of 18 Old 01-05-2018, 08:16 AM
JnC
JnC's Avatar
Thanks (Given): 69
Likes (Given): 26
Likes (Received): 220
I can attest to this notion due to first hand experience. My 89 Yamaha ys624 came with e sediment tube under the fuel petcock, unfortunately it was missing when I got the machine as the original owner broke it and had a shop replace it with just a fuel line. I installed a 90 degree fuel shut off valve and installed a fuel filter as well, after a few uses it was evident that there was fuel starvation as the machine would die after a few minutes of use, at first I thought it was a fuel vent problem but that was not the case, replaced the fuel filter with a straight fuel line and issue was resolved.
The YS828 that I have does have a filter though as that unit comes with a standard fuel pump and is not gravity fed.
picture of the YS624 with the filter.
JnC is online now
