Tecumseh engine replacement - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 01-05-2018, 08:00 AM Thread Starter
I have a Noma 10/27 snowblower with a blown 10hp Tecumseh engine. If I buy another engine what should I look for so that it mounts and works properly? This is the info that I have on the snowblower.
MODEL SERIAL
Noma Signature 200152
CN 1027DE 2265
582978
HMSK100 159212S SER 2252D
Newt is offline
post #2 of 3 Old 01-05-2018, 08:16 AM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 146
Need to know if it has one or two pulleys, All you need to do is pull off the belt cover and if both belts are on the same shaft itís a single, the second pulley is gear driven in the front of the case and it uses the same gear as the governor, can be tough figuring it out with the numbers.
Dauntae is online now
post #3 of 3 Old 01-05-2018, 09:06 AM
Thanks (Given): 229
Thanks (Received): 199
Likes (Given): 2030
Likes (Received): 516
the tecumseh camshaft pn is 35375. This suggests a single-shaft output...much more conducive to repower.
('87 Toro 38150 826)
classiccat is online now
