Inspected my belts? - Snowblower Forum : Snow Blower Forums
post #1 of 17 Old 01-18-2018, 03:17 AM Thread Starter
Cardo111's Avatar
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
Inspected my belts?
I tightened the slack in my auger drive cable and took off the belt cover on this machine for the first time (Ariens Platinum 24 SHO model 921038). I noticed the edge of the forward most auger belt (the one closest to the impeller) is frayed along one of the edges. Was this caused by the tensioner being a little loose? Also is it normal to hear the auger tension/idler pulley bracket slap against the tractor frame whenever you release the auger lever? May have just not noticed that sound over the years. As always I appreciate your insights.
Cardo111 is offline
post #2 of 17 Old 01-18-2018, 03:43 AM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
pulleys should never be hitting anything.
if belt is frayed on one side then something is not lined correctly. with cover off operate the auger, post a vid if u can
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #3 of 17 Old 01-18-2018, 11:30 AM
Thanks (Given): 65
Thanks (Received): 122
Likes (Given): 102
Likes (Received): 150
I will check my belts today for the slight fraying you are experiencing. Does not look like anything to worry about. The auger clutch arm is supposed to lightly touch the frame according to the Ariens owner manual. I have always noticed it and it does not bother me. I often release the auger clutch quickly when doing the EOD and a car is coming toward me and it is a noticeable metal impact noise. The manual says to disengage the auger clutch and lightly move the clutch lever so you can hear the slight metal contact of the arm and frame (highly paraphrased since I cannot copy it).
Good luck.
Town is online now
post #4 of 17 Old 01-18-2018, 11:42 AM
leonz's Avatar
Thanks (Received): 90
Likes (Given): 76
Likes (Received): 177
Fraying is a symptom of V belt wear and the V belt needs to be changed. If you can afford it a Kevlar V belt as a replacement for each one will provide you with the best V belt for resistance to the shock loading that occurs with snow blowers.
Your belts are not under continuous loading and the shock of putting multiple shock loading times times on a V belt will cause what you see.
Putting a bar of Irish spring under the snow blower in the off season will keep the mice out and the belts will not be chewed on.
Last edited by leonz; 01-18-2018 at 11:43 AM. Reason: stuff/spelling and punctuation corrections
leonz is offline
Likes jonnied12 liked this post
post #5 of 17 Old 01-18-2018, 11:49 AM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 146
Likes (Received): 286
I was hearing that snap on a Sno-Tek and it turned out it was the roller that holds the auger break open, When I pulled and released the lever the roller moved on the flat part and when it got to the angled part it would snap shut putting the brake against the pulley.
Dauntae is online now
post #6 of 17 Old 01-18-2018, 12:51 PM
Thanks (Given): 65
Likes (Given): 102
I checked my auger belts and there is no fraying and the belts are riding just below the top of the groove. If the belts are not riding in the center of the idler wheel there is a sharp square edge at each side of the idler wheel that could slightly fray the top edge of the belt. But that fraying is so slight it is not going to affect belt life or performance. If the belt is riding at or near the top of the groove in engine auger pulley then I think it is good to go. It may be possible to align the idler wheel with the belt by shimming the position of the idler wheel in the adjustable bracket.
I also checked where the clutch arm contacts the metal chassis, it is at the top of the chassis at the belt opening where the arm makes contact.
Good luck.
Town is online now
Likes Cardo111 liked this post
post #7 of 17 Old 01-18-2018, 03:26 PM Thread Starter
Cardo111's Avatar
Likes (Given): 79
I appreciate the responses. The last 2 winters here have been very light (so far), this machine may have 10 hours on it tops. I agree the edge damage on the belt is slight and doesn't warrant replacement at this point. I am not too impressed with the quality of sheaves in this unit as well. The back traction one is actually plastic. Additionally the dual belt "SHO" sheave seems pretty small and a bit rough along the lip edges. I attached some additional photos (one of the nicked up a bit sheave and the other of the auger belts under tension). The belt with the edge fraying a bit (one closest to the chute in the original photo) is looser than the other auger belt under tension. I am going to adjust the idler pulley in a bit and hope this will address that.
Cardo111 is offline
post #8 of 17 Old 01-18-2018, 03:28 PM Thread Starter
Cardo111's Avatar
Likes (Given): 79
Pic of the sheave
Cardo111 is offline
post #9 of 17 Old 01-18-2018, 03:33 PM Thread Starter
Cardo111's Avatar
Likes (Given): 79
Another pic of belts under tension.
Cardo111 is offline
post #10 of 17 Old 01-18-2018, 03:43 PM
Likes (Received): 303
thtyj
