Ariens snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-24-2018, 03:09 PM Thread Starter
I got older Ariens snowblower,changed points and condenser and coil,still no spark,how do I ground the motor,???plz HELP,I did all that even changed flywheel mags are fine,I don't think it's grounded tho,need help in where to run wires plz
ironbill is offline
post #2 of 5 Old 01-24-2018, 03:13 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Given): 467
Likes (Received): 813
Check the Flywheel Magnets, They may have Dislodged.
Jackmels is online now
post #3 of 5 Old 01-24-2018, 05:55 PM
Thanks (Given): 573
Thanks (Received): 749
Likes (Given): 4247
Likes (Received): 1681
to SBF ironbill
Grounding it is how you shut it off or kill the spark. You want to make sure none of the wires are nicked and grounding including those running to the throttle lever or on/off key should you have one.
What did you use to set the point gap and coil gap ??
post #4 of 5 Old 01-25-2018, 12:38 AM
Thanks (Given): 26
Likes (Given): 83
Likes (Received): 240
If you are talking about the wires to the throttle and/or any interlocks, they need to *un*-grounded. Grounding these lines shuts down the magneto and stops the engine. Plug ground is through the block, and no other wiring outside the mag should be needed to run.
tadawson is offline
post #5 of 5 Old 01-25-2018, 09:06 AM
69ariens's Avatar
Thanks (Received): 39
Likes (Given): 53
Likes (Received): 100
Double check the points are set right. Check magnets if all that's good and still no spark replace coil
Scott
69 ariens
toro 721r
toro 926 hd oxe
69ariens is offline
