$20 Amazon Tachometer - Do they work? - Snowblower Forum : Snow Blower Forums
post #1 of 21 Old 01-26-2018, 07:16 PM Thread Starter
Dannoman's Avatar
Thanks (Received): 18
Likes (Received): 119
They're cheap. But I don't want to spend a lot on something I might do only once in a blue moon. Here's the link...
If they give me an accurate RPM reading even just this once, I'd say it's worth it.
Update. I found this review on Youtube...
Dannoman is offline
post #2 of 21 Old 01-26-2018, 08:10 PM
Thanks (Given): 56
Thanks (Received): 62
Likes (Given): 51
worked for me, single wire, internal battery, i got this one from ebay. my vid on it
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #3 of 21 Old 01-26-2018, 08:24 PM Thread Starter
Dannoman's Avatar
https://www.youtube.com/watch?v=mIZIfEEdzqI&t
Cool! I noticed your engine speed was between 3,400-3,500 RPM at high throttle. What is the recommended engine speed for a 10HP Tecumseh Snow King?
Dannoman is offline
post #4 of 21 Old 01-26-2018, 11:52 PM
GoBlowSnow's Avatar
Thanks (Received): 83
Likes (Given): 56
Likes (Received): 249
Been using mine for about 3 years now but the non-replaceable battery is just about shot.
GoBlowSnow is offline
post #5 of 21 Old 01-27-2018, 12:47 AM
Thanks (Given): 56
Likes (Given): 51
my craftsman manual specs it @3700rpm
mine is replaceable but u can pry yours open to get to the battery
vinnycom is offline
post #6 of 21 Old 01-27-2018, 08:01 AM
Likes (Given): 23
Likes (Received): 216
Pry open the bottom plate and you will be able to replace the battery. I changed mine. You will need a sharp knife.
RIT333 is online now
post #7 of 21 Old 01-27-2018, 08:49 AM
Thanks (Given): 118
Thanks (Received): 277
Likes (Given): 358
Likes (Received): 633
Any chance it kept the hour reading when you changed the battery?
I wonder if there'd be a way to connect a capacitor to help keep your hours count during the battery change. But that's probably over-thinking it.
RedOctobyr is offline
post #8 of 21 Old 01-27-2018, 08:56 AM
tpenfield's Avatar
Thanks (Given): 48
Thanks (Received): 56
Likes (Received): 190
I have the fancier version of the 'Searon' RPM meter, also does volts and hours and is flush mounted. Seems to work fine. One thing to be sure of is to get the ignition sensor lead ( assuming it has one) wrapped around the sparkplug wire good & tight.
I wrapped some electical tape arounf the sensor, once it was wrapped around the sparkplug wire, so it stays tight.
Regards, Ted
Current & Past Fleet:
2017 Husqvarna ST224 (SOLD)
2003 Ariens ST824LE (SOLD)
tpenfield is offline
post #9 of 21 Old 01-27-2018, 09:40 AM
Thanks (Given): 510
Thanks (Received): 681
Likes (Given): 3844
Likes (Received): 1478
The older ones were sealed by pouring something into the case to make them waterproof. I was mad when I found that out but the one on my rider is still going 3+ years later and the newer ones I've purchased do have replaceable batteries. Just need to make sure it says so in the ad. I love these things, simple, cheap, easy to install and work great.
I keep one loose to use as a tach on engines I'm working on I don't intend to keep. Pull it out of the tool box, couple wraps on the ign wire, tie wrap, adjust mixture, set idle, WOT and then cut the tie wrap and put back in the tool box. So much nicer to know you have it set than to guess it sounds about right.
post #10 of 21 Old 01-27-2018, 10:12 AM
Likes (Given): 23
Not sure, bc I only use it for the tach.
