Adjust Idle on Non-Adjustable Tecumseh Carb - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-28-2018, 07:17 PM Thread Starter
Dannoman's Avatar
Thanks (Given): 9
Thanks (Received): 19
Likes (Given): 46
Likes (Received): 122
The machine is running better and now I'm getting a bit picky. It does pop a little bit through the muffler from time to time so that tells me the carb could be running too lean. Now, do I fix this by adjusting the idle screw on top of the carb and open it up a bit (more fuel) and that would be to the right - or is it the other way? Or is there something else to try?
Dannoman is offline
post #2 of 7 Old 01-28-2018, 07:30 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 182
that screw just sets your low idle speed/rpm when the throttle lever is at its lowest, it does not adjust how much fuel is metered into engine, thats why its a non adjustable carb, but there are ways around that iirc by opening up the main jet w/a drill bit, ymmv. or just buy a clone adjustable carb off ebay/amazon.
a little pop once in awhile is fine, but an adjustable carb is better to try to mitigate it.
MY VIDS ON FIXIN HER UP
vinnycom is online now
post #3 of 7 Old 01-28-2018, 07:35 PM Thread Starter
Dannoman's Avatar
Thanks (Given): 9
Likes (Given): 46
Thanks Vinny. Not sure I feel confident about drilling a new hole for the main jet...
I don't know if this would work, but I have an adjustable main jet from a rebuild kit. Could I swap the adjustable jet for the non-adjustable one on the existing carb or is that a no go?
Dannoman is offline
post #4 of 7 Old 01-28-2018, 08:00 PM
Likes (Given): 21
Likes (Received): 30
I think you can change the carb out for an adjustable. You'll have to research more or hopefully someone will chime in. On the other had they're <$15.
Jatoxico is offline
post #5 of 7 Old 01-28-2018, 08:10 PM Thread Starter
Dannoman's Avatar
Thanks (Given): 9
Likes (Given): 46
Yeah. The Chinese carbs on Ebay and Amazon are cheap and apparently good. I am tempted to see if I can modify (convert) my old carb by swapping the adjustable main jet for the fixed jet. Has anyone tried this with any success?
UPDATE - It looks like my idea is a no-go. At least on one other site someone says it can't be done...
Dannoman is offline
post #6 of 7 Old 01-28-2018, 08:15 PM
Likes (Given): 21
I just installed a replacement today and it works fine. I'm not sure you can just put in the bowl/jet. But if the old one bolts up it should work. Take a look at pics side by side and make sure the linkages all are the same.
Jatoxico is offline
Likes Dannoman liked this post
post #7 of 7 Old 01-28-2018, 10:44 PM
Likes (Received): 11
I picked up a adjustable one for my Toro and love that I can dial it in perfect. You might try knocking on the choke lever one click to richen it up
cdestuck is online now
