Got Lucky Today - Snowblower Forum : Snow Blower Forums
post #1 of 31 Old 01-30-2018, 03:15 PM Thread Starter
Thanks (Given): 260
Likes (Given): 90
Likes (Received): 62
Got Lucky Today
Out doing the EOD and decided I better shovel it instead of blowing it as I'm on a dirt/gravel road and the plow will often shove up rocks/boulders as it plows. Sure enough I shoveled a grapefruit size boulder out of the EOD pile.
Can anyone advise about how big a rock does it actually take to do real damage?
Are you generally okay with rocks smaller than a golf ball? Being new to blowers I have no idea, so thank you in advance for any education.
*Kind of sucks being on a dirt/gravel back road.
barney is offline
post #2 of 31 Old 01-30-2018, 03:29 PM
jrom's Avatar
Thanks (Given): 348
Thanks (Received): 107
Likes (Given): 1068
Likes (Received): 188
I hear ya about living on a gravel back road. I still think the positives outweigh the negatives (at least here).
I'd say that your shear pins should do their job of just about anything that may make its way into your auger or impeller. Good idea to make sure the shafts are loose and lubed up and that you use proper shear pins/bolts.
About twenty years ago a good size rock made it past the augers, into the impeller, made one heck of a dent in the impeller housing on its way out the chute. Sure seemed like a good size rock.
Honda HS828TAS (1991) Made in Japan with Thai built GX240
Honda HSS1332ATD (Late-2015) Made in USA with Thai built GX390
180" to a rare 350" of snow per year (Alberta Clippers & Lake Michigan), 644' gravel driveway, 2 vehicle parking areas, 500' of trails around small house with an unheated garage.
jrom is offline
Thanks barney thanked for this post
post #3 of 31 Old 01-30-2018, 03:42 PM
Thanks (Given): 21
Likes (Given): 172
Likes (Received): 28
I live on a private, gravel road. Under the gravel is what they call 3 to 6. The rocks are 3 inches to 6 inches in size. I have picked up and thrown several of them over the years and yes, they do put a nice dent in the impeller housing.
AriensPro1128 is offline
post #4 of 31 Old 01-30-2018, 03:48 PM
Likes (Received): 45
I had a gravel driveway which was really crusher run when I bought my Honda 724. I threw so many stones that I went back to using my Farmall Cub with a plow (didn't dent anything but really scoured the paint off the inside of the chute). When I could afford to pave it I went back to the blower.
dhazelton is offline
post #5 of 31 Old 01-30-2018, 03:55 PM
Guest
Thanks (Given): 20
Thanks (Received): 54
Likes (Given): 40
Likes (Received): 94
picked up a big paver one time into the 624 powershift, no big damage just a dent ,
10953 is offline
post #6 of 31 Old 01-30-2018, 04:35 PM
Likes (Received): 344
If the rock makes it through the auger through the impeller without jamming, then almost anything is possible. Having said that, I once sold a blower to a lady and her son used it on gravel. He ended up jamming a piece of gravel about the size of a marble between the auger rake and the housing, jamming the machine. Flip side of that was the time I took a very large chunk of ice totally through a machine successfully. I know it went through because I watched it arc and come very close to a parked car.
HCBPH is offline
post #7 of 31 Old 01-30-2018, 04:38 PM
Thanks (Given): 573
Thanks (Received): 749
Likes (Given): 4246
Likes (Received): 1679
I'd be more concerned with smaller rocks that can get jammed between the impeller and housing. That's why I drive over the first and maybe second snowfall. That way I have the gravel in the driveway packed down a bit before running the blower over it. A big rock shooting out the machine is nothing to take lightly but if it goes through I think you're better off then when you suck in smaller stones that can jam the impeller and having to get in there and replacing the pins that will snap or possibly damage the impellers bearing or bearing housing.
From the answers I'm guessing each case is a little different and so is the solution.
Likes jrom liked this post
post #8 of 31 Old 01-30-2018, 04:45 PM Thread Starter
Thanks (Given): 260
Likes (Given): 90
Sounds like I'm living on borrowed time then as I'm picking and shooting five or ten smaller stones every time out.
barney is offline
post #9 of 31 Old 01-30-2018, 04:48 PM Thread Starter
Thanks (Given): 260
Likes (Given): 90
So, do you guys who live on dirt/gravel roads and rock laden EOD shovel? Or is it dam the torpedoes, full speed ahead.
barney is offline
post #10 of 31 Old 01-30-2018, 05:18 PM
jrom's Avatar
Thanks (Given): 348
Likes (Given): 1068
I've only used a shovel a few times to break up ice or super hard pack.
We get enough snow here that it was only early and late in the season that I would get the gravel snow, and then it was "fire away" and literally watch out for people and vehicles in the path of that stream.
About 8-9 years ago, the county decided to pave 1/5 of my road and the pavement ends at my property line. I can go left on asphalt, or right on gravel (for 4 miles before you hit a highway), so fortunately I can avoid the gravel snow bomb now, but for almost twenty years I had to deal with it.
jrom is offline
