Toro Powerlite vs CCR 2000 - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 02-07-2018, 01:27 AM Thread Starter
I have a Powerlite 16" 3.25 hp snowblower that was given to me. It's at the shop now and I've never used it. The fella at the shop told me it looked to be in great condition and that these are excellent little machines. I have found a CCR 2000 which I believe is a 20" with 4.5 hp. I could probably pick up the slightly larger CCR for less than what the shop is going to charge to fix the Powerlite. Which is the better machine overall? Maybe I will just own both..
Sent from my SM-J327T1 using Tapatalk
erichall84 is online now
post #2 of 15 Old 02-07-2018, 07:27 AM
Cardo111's Avatar
Thanks (Received): 127
Likes (Given): 79
Likes (Received): 172
aboard!
Those are regarded to be excellent machines but they're loud 2 strokes. Based on the specs I would think that the CCR 2000 is the higher capacity and more powerful machine. Best of luck with it or them.
https://www.manualslib.com/manual/79...00.html#manual
Cardo111 is offline
post #3 of 15 Old 02-07-2018, 08:08 AM
Thanks (Given): 101
Likes (Given): 264
Likes (Received): 147
Eric, if these are cheap, I'd probably buy both and see what's still running after 5 hrs of use.
Welcome aboard !!
uberT is offline
post #4 of 15 Old 02-07-2018, 08:44 AM
Thanks (Given): 95
Thanks (Received): 194
Likes (Given): 74
Likes (Received): 449
Some on here have mentioned that the ignition is expensive. You may want to have both with one being a parts machine. Plus they use Suzuki engines and parts are expensive for those. I like the type of auger belt they have.
post #5 of 15 Old 02-07-2018, 09:18 AM
Snowbelt_subie's Avatar
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 208
i would take the 2000 all day you should be able to do 12" with the 2000 the 3hp powerlite will struggle with anything over 6"
Toro ccr3650 6.5hp RTEK ....Craftsman SS ???
....Honda HS624 GX160
Snowbelt_subie is offline
post #6 of 15 Old 02-07-2018, 09:18 AM
Thanks (Given): 101
Likes (Given): 264
Originally Posted by WiszMan
There's nothing more expensive than a cheap, used CCR 2000.
I saw a pair of these machines sitting on the side of the road last week, each priced at $150 They looked tired.
uberT is offline
post #7 of 15 Old 02-07-2018, 09:20 AM
Thanks (Given): 20
Likes (Given): 59
i sold 3 of them this season for $150 each
post #8 of 15 Old 02-07-2018, 09:28 AM
stromr's Avatar
Thanks (Received): 38
Likes (Received): 63
Smile It's a win win to me!
Either machine properly maintained is a winner. Toro pretty much invented this design and everybody else has copied it. My 1995 Toro CCR 1000 with the Tecumseh 3 HP 2 cycle regularly goes thru 8-10" of all types of snow. I will always have a 2 stage too but the single stage is priceless for speed and cleaning right down to the surface.
The only draw back in your case is the Suzuki engines are expensive to fix. The plus is 2 cycles at the slow speeds these run, 4250 rpm or less last a long time.
stromr is offline
post #9 of 15 Old 02-07-2018, 09:46 AM
Thanks (Given): 20
Likes (Given): 59
the expensive to fix part doesn't really apply. i see them all the time for 40-70$ if something expensive breaks buy another one take the parts off. you can buy 3 machines for $150 if you do it right.
as far as performance i am sure the 3hp versions are ok but i have had lots of single stage blowers over the last couple years. ccr3650's, 621e , hs621, ccr2000's and ran them side by side all with new paddles and as far as throwing distance and weight, ease of pushing.
the ccr2000 beat them in all 3.
post #10 of 15 Old 02-07-2018, 10:17 AM
Thanks (Given): 101
Likes (Given): 264
Agreed, great machine assuming it's 100% functional.
uberT is offline
