getting Snow Off 8 x 16 Deck & pool Surround Better - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 01-23-2019, 06:35 AM Thread Starter
Likes (Received): 12
Iím considering an el cheapo electric just for cleaning off the deck . Already have all the other snow gear but the deck just loves to catch the snow shovel every couple feet with either a board end or newly popped nail head. I mean itís constant even with a blunt plastic edged shovel. In short it SSUXXX. Iíve considered grabbing a 🙈 I know theyíre garbage small electric. I donít have to loft it far 6-8í right into the pool or off the side.
Anybody have any great ideas for one that might be of some 🙄small use on a once in a while basis and of course has to toss it out the side and CHEAP as I know full well not to expect much.
Also I wonder if anyone has ever had any luck gluing some sort of blunting onto the edge of their snow shovel.? Something like a slit piece of small flex line.. mine is hard on the decking hard on the shovel and literally hits something every couple feet. And itís not even a scabby warped deck🙈. I donít want it clean to the wood anyways, close is good enough.
2002 Ariens 932-101
driz is offline
post #2 of 22 Old 01-23-2019, 07:19 AM
Thanks (Given): 19
Thanks (Received): 48
Likes (Given): 107
Likes (Received): 221
You need to countersink all the nails. Either the nails are too short or improper nails. The ones that popped, I would pull and replace with deck screws. You need to predrill the ends of the boards and secure.
russ01915 is offline
Likes tabora, Lunta liked this post
post #3 of 22 Old 01-23-2019, 07:28 AM
Thanks (Given): 140
Thanks (Received): 305
Likes (Given): 406
Likes (Received): 730
I have a Toro Powercurve 1800, it's been great for clearing my deck (with the occasional nail head sticking up a bit, etc). I have bought several, for my parents, in-laws, etc, they are a huge help for small areas, and/or where a big gas machine is not practical. And no concerns about bad gas or anything. I haven't paid more than $50 on Craiglist for any of them. Given my experiences with them, and how they've held up, I'd lean towards a used Toro, vs more money for a new cheaper-brand electric.
Likes gibbs296, Freezn liked this post
post #4 of 22 Old 01-23-2019, 12:36 PM
Thanks (Received): 372
Likes (Received): 1318
A BIG OLD Leaf Blower works Slick also.
post #5 of 22 Old 01-23-2019, 01:51 PM
Thanks (Given): 140
Likes (Given): 406
For smaller & fluffy storms, a leaf blower is probably awesome. But I've cleared 18" storms, and probably deeper, all at once with my little Toro. The snow would be coming way over the top of the intake, I'd have to back up and go again to get all of it. It's really impressed me with what it's handled.
post #6 of 22 Old 01-23-2019, 04:06 PM
tabora's Avatar
Thanks (Given): 42
Thanks (Received): 203
Likes (Given): 121
Likes (Received): 396
+1 - I had the same situation, but the prior owner had used a mixture of short nails and untreated sheetrock screws! I finally had enough and pulled off all the decking, flipped it over and put it back on with Torx-head decking screws. And then ran over it all with a belt flooring sander. Problem solved!
tabora is offline
Likes russ01915 liked this post
post #7 of 22 Old 01-23-2019, 05:38 PM
Thanks (Given): 19
Likes (Given): 107
Good job. Even though it was a lot of work, your problem is solved. Anything with a rubber paddle will clear it easily.
post #8 of 22 Old 01-23-2019, 09:38 PM
Thanks (Given): 37
Thanks (Received): 70
Likes (Given): 115
Likes (Received): 142
+1 with using Toro 1800 to clear the deck. Light weight, easy to maneuver, and enough power to clear my 48" tall rails.
2009 Honda HS928WAS
2005 Honda HS520AS
1996 Honda HS621AS
2012 Toro 1800 Power-Curve
Freezn is online now
post #9 of 22 Old 01-24-2019, 05:24 AM
Lunta's Avatar
Thanks (Given): 33
Likes (Given): 110
Likes (Received): 67
No idea where you are, or what sort of snow you have.
I use a Makita 36v (2x18v) battery leaf blower to clear all decking, stairs, etc. Yesterday we had some quite "heavy" (as in not light and fluffy) snow, and the leaf blower still cleared a 15cm layer away.
No oil changes needed.
Easy to store.
Useful for front/back porches.
No risk of damage to decking.
You can even use it for leaves
Lunta is offline
post #10 of 22 Old 01-25-2019, 10:30 AM
Likes (Given): 23
Likes (Received): 19
Now I'm on a quest to find one of these for $50 myself! My deck is 14'x28' and I can't stand shoveling it any more, especially when it has >12" on it. I thought about getting some ramps to get my big blower up there, which I did in 2015 when we kept getting nailed, but if these little guys will do the job, I'm all in. Thanks for the advice.
CTHuskyinMA is offline
