John Deere 1980 model 826 Friction Wheel & Parts - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 01-26-2019, 06:48 PM Thread Starter
I scored a relic in good condition, but needs some parts. Wow am I impressed.
Low gear was sputtering and looked under the hood. Needs new friction wheel and belts.
I am having a hard time finding the correct parts diagram for the model P826J and serial number 124388. Does anyone have a pdf part list, what post to review, and/or recommendations? I have struck out on the JD.com site for the part number for the friction wheel or matching alternative. Are both belts the 1/2" x 36"?
Any help is appreciated and thanks in advance.
Ok to direct message me too.
Northe2 is offline
post #2 of 6 Old 01-27-2019, 12:45 AM
Thanks (Given): 545
Thanks (Received): 713
Likes (Given): 4045
Likes (Received): 1552
to SBF Northe2
post #3 of 6 Old 01-27-2019, 07:55 AM Thread Starter
Thanks Kiss4aFrog. What is you chose for snow removal? Multiple machines?
I have found more info since posting, but have not found the specific parts manual. Looks like eBay and/or my local JB dealer are the solution.
It is snowing now and get to use my single stage Honda HS621 I bought that was recommended here on SBF.
To add to my fun, I am converting the HM80 to the HF 212cc Predator since I have it apart.
Northe2 is offline
post #4 of 6 Old 01-27-2019, 10:22 AM
Thanks (Given): 95
Thanks (Received): 189
Likes (Given): 72
Likes (Received): 433
Partscatalog.deere.com
Belt M82612
Drive disk M114485
post #5 of 6 Old 01-31-2019, 05:07 PM Thread Starter
JLawrence08648, Thanks for the part numbers. Went to local JD Dealers in North Royalton, Ohio and bought the 2 belts and friction disc. The damage was $106.00.
Northe2 is offline
post #6 of 6 Old 01-31-2019, 08:59 PM
Thanks (Given): 545
Likes (Given): 4045
Yup. The stuff for the JD's is a bit more than others.
If you look in my garage those are some of the machines I have. I'm using a 1332 Toro PowerShift this year. I have a 1032 JD with a blown engine, 1032 JD running and an 826 JD with no spark. They are all the older Deere made JDs.
