Stator connector - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-27-2019, 10:09 PM Thread Starter
Stator connector
I am trying to find and female connector so I can attach a wire to the stator on my MDT snowblower. Seems like I have only seen people use a connector from salvaged parts for adding a light. Any links someone could share?
RacerJ is offline
post #2 of 8 Old 01-27-2019, 10:31 PM
Likes (Given): 20
I usually cut the connector off, strip the insulation off the end, twist a new wire to it the length that you need, solder the connection and heat shrink tube it.
strtch5881 is online now
post #3 of 8 Old 01-27-2019, 11:20 PM
Grunt's Avatar
Thanks (Given): 259
Thanks (Received): 319
Likes (Given): 3145
Likes (Received): 628
Welcome to SBF Racer. I usually use these bullet connectors for lights. Put the female on the stator wire and the male on the light.
Name:	ScreenHunter_205 Jan. 27 21.17.jpg
post #4 of 8 Old 01-27-2019, 11:23 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 58
Do a search for Molex 2 pin connector on ebay.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #5 of 8 Old 01-28-2019, 12:34 AM
SimplicitySolid22's Avatar
Thanks (Received): 77
Likes (Given): 74
Likes (Received): 121
Racer what does your wire look like coming from engine...I might be trying to fin the same piece as well.
Look at photo in this link....is this the wire you are thinking about?????
I am sure it is what I need....took me a while to find it finally.
https://www.ereplacementparts.com/ar...26_157769.html
SimplicitySolid22 is offline
post #6 of 8 Old 01-28-2019, 12:34 AM
Likes (Given): 74
Click on engine and belt to see wire connector....
post #7 of 8 Old 01-28-2019, 04:25 PM Thread Starter
Yes that appears to be the connector I think I would like. I tried to search for Molex 2 and only found 2 pin connectors when I only need a single connector. I just wanted to avoid cutting off the factory connector, but that is probably the best way. Thanks for the responses!
RacerJ is offline
post #8 of 8 Old 01-28-2019, 05:28 PM
Motor City's Avatar
Sorry, I thought it was a 2 pin. Still may be made by Molex.
Ariens ST11528LE
Honda HS720
