Protect engine exterior from corrosion, spray? - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-29-2019, 08:58 AM Thread Starter
Likes (Received): 23
I haven’t used Fluid Film, which seems to protect everything including warn out knees. But it does mention to keep it away from non-oil resistant rubber. With a spray it would be difficult to avoid all rubber components.
Are there any other sprays that I should consider for general corrosion protection for a blower that lives in a shed that are okay on all engine parts (exterior).
trellis is offline
post #2 of 10 Old 01-29-2019, 10:15 AM
tdipaul's Avatar
Thanks (Given): 78
Thanks (Received): 81
Likes (Given): 315
Likes (Received): 342
I tried Fluid Film on an engine once and its not ideal for this app IMO. Its too thick and makes a mess and attracts dirt.
But I am pretty convinced it works at deterring rodents because they dont like to crawl on the goo that never evaporates.
Happy using WD40 on OPE and motorcycle engines since the 80's and they look like new and dont get any rustier than when I purchased them (if pre-owned)
1989 John Deere 1032
tdipaul is online now
post #3 of 10 Old 01-29-2019, 10:50 AM Thread Starter
thanks, I was wondering about spraying the rubber parts with a silicone spray first and then followup with WD40 while trying to avoid the rubber. This would be easiest since I have both.
trellis is offline
post #4 of 10 Old 01-29-2019, 11:25 AM
tdipaul's Avatar
Thanks (Given): 78
Likes (Given): 315
sounds like the perfect combo
post #5 of 10 Old 01-29-2019, 11:31 AM
Likes (Received): 18
So am I reading this right? I can spray WD40 all over my engine, including the muffler, and it will be safe and protect it from rusting more than it has already?
Sent from my SM-J320V using Tapatalk
Smolenski7 is offline
post #6 of 10 Old 01-29-2019, 11:39 AM
orangputeh's Avatar
Thanks (Given): 726
Thanks (Received): 216
Likes (Given): 1378
Likes (Received): 1381
I am not sure if anything is good to apply on Honda tracks. I have had tracks that are 25 years old that look good as new. the machine is in garage and not left out in the sun which is the rubber killer.
"It Feels Like Beer O'Clock "
orangputeh is offline
Likes Prime liked this post
post #7 of 10 Old 01-29-2019, 12:00 PM
tdipaul's Avatar
Thanks (Given): 78
Likes (Given): 315
Yes, been doing it my entire adult life.
and including the muffler
when the OPe is washed (1 or 2x yr) and when every dirt bike owned since the 80's is washed after every ride (XR350, HUS 400WR, SUZ RMX250, Yam WR426).
No ADDITIONAL problems with corrosion and looks great
keep it off the brakes and tires and use simple green on these
post #8 of 10 Old 01-29-2019, 12:02 PM Thread Starter
Some protects like Armor All pitch their UV inhibitors, although not sure about it's use here.
So I took a look on the shelf and my silicone spray is almost empty. So with a quick search I found a WD product that aims to protect all materials.. metal and rubber and has a high temp rating too. And seems to be lowcost too:
https://www.wd40specialist.com/pdf/s...t-silicone.pdf
maybe?
trellis is offline
post #9 of 10 Old 01-29-2019, 12:14 PM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 28
Likes (Received): 39
I'm not too sure about silicone on tires, or tracks, it might make them slick. but it will make them look good.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is offline
post #10 of 10 Old 02-02-2019, 01:54 AM
Snowslinger's Avatar
Likes (Given): 49
Likes (Received): 9
Ive only recently been given my first snow blower but Iíve started using silicone on all the auger bits and housing as well as inside the chute. Iíve also sprayed and wiped it on the outter painted bits and pieces as well to try to help protect them a bit almost like a wax.
I havenít thought yet of coating the engine parts but thatís a great idea especially since I currently store mine in an outdoor shed that stays cold. I try not to put it away wet but itís nearly impossible. The last storm we had I was out there with a blow dryer making sure everything was dry.
1999 MTD E662E 24Ē with 10HP Tecumseh Engine.
Snowslinger is offline
