Long Bolt Holding Muffler Fell Out - Stripped... - Snowblower Forum : Snow Blower Forums
post #1 of 19 Old 01-30-2019, 12:30 PM Thread Starter
Dannoman's Avatar
Thanks (Given): 13
Thanks (Received): 19
Likes (Given): 50
Likes (Received): 124
My old Tecumseh 10HP started fine this morning but the vibrations made one of the long bolts holding the muffler assembly fell out. It is stripped so I need to find a way to secure it - or maybe there is a long bolt with a bit bigger thread out there...
Dannoman is offline
post #2 of 19 Old 01-30-2019, 12:34 PM
Thanks (Given): 13
Thanks (Received): 126
Likes (Given): 146
Likes (Received): 289
As long as itís not broke off you can put a heliciol in, Iím waiting on a kit for a stripped spark plug hole so Iím doing the same.
Dauntae is online now
post #3 of 19 Old 01-30-2019, 12:39 PM Thread Starter
Dannoman's Avatar
Thanks (Given): 13
Likes (Given): 50
That's an insert you need to tap the hole in first for, correct? Any idea what size might I need?
Dannoman is offline
post #4 of 19 Old 01-30-2019, 12:41 PM Thread Starter
Dannoman's Avatar
Thanks (Given): 13
Likes (Given): 50
Got it. Mounting bolts muffler genuine Tecumseh 651002. For Tecumseh engines 5/16-18 x 4-3/16 "
Dannoman is offline
post #5 of 19 Old 01-30-2019, 12:47 PM
db130's Avatar
Thanks (Given): 16
Likes (Given): 238
Likes (Received): 198
Are you using the strip of metal that keeps the bolts from turning, Tecumseh part number 31588?
db130 is online now
Likes Bondo 287 liked this post
post #6 of 19 Old 01-30-2019, 12:53 PM Thread Starter
Dannoman's Avatar
Thanks (Given): 13
Likes (Given): 50
dh: I have that strip but it came out anyways...
Dannoman is offline
post #7 of 19 Old 01-30-2019, 01:10 PM
db130's Avatar
Thanks (Given): 16
Likes (Given): 238
Tapping to a larger bolt size:
Helicoling it:
db130 is online now
post #8 of 19 Old 01-30-2019, 01:48 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Given): 466
Likes (Received): 811
Rather than Mess with Threads, I just use a Screw in Type Muffler. Sometimes have to Mod the Air box.
Jackmels is online now
Likes jrom liked this post
post #9 of 19 Old 01-30-2019, 02:01 PM
Thanks (Given): 95
Likes (Given): 74
Likes (Received): 449
The screw on mufflers are cheap. I sometimes use them with black pipe the threads coated with Never-Seize.
post #10 of 19 Old 01-30-2019, 03:48 PM Thread Starter
Dannoman's Avatar
Thanks (Given): 13
Likes (Given): 50
Thanks everyone.
Does anyone have a link to this part?
Dannoman is offline
