Loud noise turning off - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-30-2019, 01:32 PM Thread Starter
Today was the first time I got to use my new Arien 28 Deluxe. This was my first time using a snow blower, when I turned the machine off it made a loud bang, almost like a gun shot. Is this normal, or should I be concerned?
kschneid3 is offline
post #2 of 7 Old 01-30-2019, 03:17 PM
Likes (Received): 18
Not normal.
How did you turn it off?
Sent from my SM-J320V using Tapatalk
Smolenski7 is offline
post #3 of 7 Old 01-30-2019, 03:26 PM
Wes Kootenay's Avatar
Was it a metallic bang or an engine backfire?
Wes Kootenay is online now
post #4 of 7 Old 01-30-2019, 03:27 PM
Thanks (Received): 96
Likes (Given): 39
You may want to power it down slowly. This can happen because the EPA want engine to run very lean.
RIT333 is online now
post #5 of 7 Old 01-30-2019, 05:18 PM
e.fisher26's Avatar
Thanks (Received): 50
Likes (Given): 44
Likes (Received): 69
Back fire, one more for throttle down before shutdown
Sent from my iPad using Tapatalk
e.fisher26 is offline
post #6 of 7 Old 01-30-2019, 06:16 PM
tabora's Avatar
Thanks (Given): 43
Thanks (Received): 233
Likes (Given): 133
Likes (Received): 453
On my Toro Zero Turn mower with a 14 HP Briggs & Stratton, it MUST be turned off at full throttle, or I get an afterfire that sounds like a 30-06 firing. (Backfire is through the carb, afterfire is through the muffler.) There's actually lingo in the Owners Manual:
To stop the machine, move the traction control levers to neutral and separate to the brake position, disengage the PTO, ensure the throttle is in the fast position, and turn the ignition key to off.
B&S - Possible Fixes for Afterfire:
  • Change to a different non-alcohol or alcohol brand fuel. Gasoline that contains alcohol has a tendency to ignite easier, which can cause afterfire.
  • Ensure proper carburetor adjustment for optimal engine performance.
  • Check the anti-afterfire solenoid for proper operation. If equipped with an anti-afterfire solenoid, shut engine off at full throttle.
tabora is online now
Likes e.fisher26 liked this post
post #7 of 7 Old 01-30-2019, 07:58 PM
orangputeh's Avatar
Thanks (Given): 749
Thanks (Received): 224
Likes (Given): 1510
Likes (Received): 1520
since this is new i would call dealer..
like others have mentioned, throttle down before shutting off and see if it still happens.
warranty?
"It Feels Like Beer O'Clock "
orangputeh is online now
