THE RIGHT TIRE PRESSURE: THE MAXIMUM ISNíT THE BEST, What PSI are you running? - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 02-04-2019, 08:36 PM Thread Starter
Homesteader's Avatar
Likes (Received): 33
How low do you go?
What tires?
Do you run chain?
Do you max out PSI?
Ariens ST1032 924084 (ST1232)
MODS: Tecumseh OHSK120 12hp, 3" Pulley, 6 Blade Impeller Kit, Hand Warmers w/ on-off switch, 1700 Lumen LED bulb,Front Weight Bar 18.5lbs, Chute Clean Out Tool, Tire Chains, Drift Cutters, Armorskids
Homesteader is offline
post #2 of 27 Old 02-04-2019, 08:38 PM
e.fisher26's Avatar
Thanks (Received): 46
Likes (Given): 43
Likes (Received): 59
8-10 psi
No chain
Noma 10/29
Cub cadet 5/26 conv to 8/26
Toro 8/24
Husqvarna st230p
e.fisher26 is online now
post #3 of 27 Old 02-04-2019, 08:41 PM
Thanks (Received): 25
Likes (Received): 78
I'm running about 12 psi at the moment. I go by a combo of how the tires sit against the ground and whether I'm having traction problems.
rslifkin is online now
post #4 of 27 Old 02-04-2019, 08:56 PM
Thanks (Given): 129
Likes (Given): 388
Likes (Received): 697
About 10-12 psi (rated to 20, I think), Carlisle Sno-Hogs, I'm using chains. Though the chains are very old and smooth (I've already flipped them once), they should probably be replaced. They seem to slip more easily than they should.
I do wonder how much difference better tires, like X-Tracs, would make.
post #5 of 27 Old 02-04-2019, 09:12 PM
tdipaul's Avatar
Thanks (Given): 78
Thanks (Received): 81
Likes (Given): 312
Likes (Received): 342
X-Tracs, no chains
Inflated to the max rating printed on the sidewall
This way it'll go farther in time before needing air again
On the snow and ice, the difference in traction between max psi and on the verge of coming off the bead isn't that much.
1989 John Deere 1032
tdipaul is online now
Likes rod330 liked this post
post #6 of 27 Old 02-04-2019, 09:41 PM
Likes (Given): 29
X-Tracs.
I'm at the recommended 14 psi.
No chains. None needed.
PaulMys is offline
Likes uberT liked this post
post #7 of 27 Old 02-04-2019, 10:01 PM
Thanks (Given): 95
Thanks (Received): 189
Likes (Given): 72
Likes (Received): 433
10-12 psi, pump to 12, fill at 10; Customers machines 15psi.
JLawrence08648 is offline
post #8 of 27 Old 02-04-2019, 10:09 PM
Thanks (Given): 101
Likes (Given): 254
Likes (Received): 141
I follow the recommendation made by the snow blower mfr.
uberT is online now
post #9 of 27 Old 02-05-2019, 12:05 AM
WVguy's Avatar
Thanks (Received): 40
Likes (Received): 155
Same here. For the Ariens Deluxe 24 that's 20 psi.
WVguy is offline
post #10 of 27 Old 02-05-2019, 12:56 AM
SnowH8ter's Avatar
Thanks (Received): 17
Likes (Received): 54
Wounded 30-inch Mastercraft (MTD) circa 96
17 ST330P Husky
SnowH8ter is offline
