Impeller clearance mod 2 questions... - Snowblower Forum : Snow Blower Forums
post #1 of 16 Old 02-05-2019, 07:33 PM Thread Starter
Snowslinger's Avatar
Likes (Given): 49
Likes (Received): 9
I just finished up adding some mud flap rubber to the three impeller blades. I made them tight enough to rub a little. I can still move the impeller around by hand but it is noticeablely more difficult than before. Will it damage the machine to run it under load like this until the rubber wears down enough? I canít imagine that itís too much more load than a heavy wet snow but my concern is that itís preloaded with tension until those pieces wear down.
Secondly, will the additional velocity damage the plastic chute? I was told it may but since the snow is going pretty much straight up out of the chute I donít really see how. I could see it moving the little hinged tip of the chute that you can move back into the straight position if I had it at a 90 degree but even then I couldnít see it damaging anything but instead just moving it back to straight.
Any thoughts?
Thanks!
1999 MTD E662E 24Ē with 10HP Tecumseh Engine.
Snowslinger is offline
post #2 of 16 Old 02-05-2019, 07:45 PM
aldfam4's Avatar
Thanks (Given): 246
Thanks (Received): 46
Likes (Given): 669
Likes (Received): 123
Snowslinger, I have done this mod on my Ariens 10HP and Craftsman 10HP with no problems to the chute. My Ariens is a metal chute and the Craftsman is a plastic chute and they handle it. I would recommend lubricating the impeller housing before trying it out, it will help with the break in period. Word of caution, watch wear you aim your chute.., you could take out a window. Best of Luck!
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is online now
Thanks Snowslinger thanked for this post
post #3 of 16 Old 02-05-2019, 08:15 PM
Thanks (Given): 137
Thanks (Received): 304
Likes (Given): 401
Likes (Received): 723
I don't know how tight your impeller is. Only my opinion, I chose not to add a lubricant when running mine in. You *want* it to wear down the rubber, quickly.
Maybe start at moderate/low RPMs, engage the augers, and see if you smell a burning belt, or hear a belt squealing.
If you can turn it readily by hand, hopefully it will be ok.
post #4 of 16 Old 02-05-2019, 08:30 PM Thread Starter
Likes (Given): 49
Likes (Received): 9
Thanks for the help! Is it okay to engage the impeller while throttled down though? I assume thatís what you meant by starting at low rpms
post #5 of 16 Old 02-05-2019, 08:44 PM
aldfam4's Avatar
Thanks (Given): 246
Likes (Given): 669
RedOctobyr, I brought my modified paddles to just touch the impeller housing, essentially their is nothing to wear down really. Lubrication - reduce any potential friction. JMTC
Toro - CCR 3650
Toro - CCR 2000
post #6 of 16 Old 02-05-2019, 09:04 PM
Thanks (Given): 137
Likes (Given): 401
Yes, that's what I meant. Like aldfam4, I also set mine up to just barely be touching the housing, so there wasn't much added friction in the first place.
If you want to add a lubricant that intentionally won't stay around forever (unlike oil/silicone), you could spray some water in there, or rubbing alcohol. Both will lubricate, making it easier to spin at the very beginning, but will go away fairly quickly. You could always add a second round of lubricant if you needed to, but I doubt it will be necessary.
post #7 of 16 Old 02-05-2019, 09:37 PM Thread Starter
Likes (Given): 49
Likes (Received): 9
Okay so it seems like I should be okay. What about starting with low rpms? Is it okay to engage the clutch for the impeller with the throttle turned down?
Thanks all
post #8 of 16 Old 02-05-2019, 09:38 PM
1132le's Avatar
Thanks (Received): 98
Likes (Given): 68
Likes (Received): 221
No lube it does not help break in it delays it
1132le is online now
post #9 of 16 Old 02-05-2019, 09:42 PM
Thanks (Given): 137
Likes (Given): 401
Yes.
post #10 of 16 Old 02-05-2019, 09:44 PM Thread Starter
Likes (Given): 49
Likes (Received): 9
I think Iíll use a little water to get it started spinning and then let it spin for a few minutes until the rubber wears down. I would think the rubber would wear down pretty quick correct?
Similar Threads
Honda HSS724AAWD Impeller Modification SkunkyLawnmowers Honda Snowblowers 28 11-11-2018 05:20 PM
My Honda HSS724AAWD (2017) Impeller Modification AKA Parkerís New Snow Boots SkunkyLawnmowers Snowblower Repairs and Maintenance Forum 1 11-10-2018 09:02 PM
Shear pin/ shear bolt theory...? d3500ram General Snowblower Discussion 22 10-11-2017 09:10 AM
Impeller shaft and bushing clearance JP Savage Snowblower Repairs and Maintenance Forum 9 12-13-2014 11:31 PM
Impeller clearance or pure power? mrplow General Snowblower Discussion 7 11-10-2013 07:49 AM
